993 Half-Cage
993 Half-Cage
Have been looking through a ton of old posts to find photos of 993s with Half-Cages and Roll Bars but haven't had as much luck as I'd like.
I know Matter are no more but that Heigo are still a valid option. I've also found out about DAS via a search on here.
Ideally I'm looking for a bolt in, with harness bar, that I can paint in body colour.
Would anyone like to share some photos of their P&J with cage/roll bar fitted?
Aribop - thanks for the photos - that looks excellent.
Mark - your comments are spot on - unfortunately, as far as I can tell, there are no DAS retailers in the UK
Ian - I've contacted Heigo and am yet to hear back. Which version do you have? If I go for the Heigo, would want the one with the harness bar. Also, my 993 'currently' has a sunroof, so it would need to fit a car with a sunroof.
mine will fit sunroof body it has the x brace and tunel supports but no belt bar i have never seen a belt bar on a hiego cage i know they make them but if you look on the fvd site it looks like a stright tube if it is there aint going to be room to move the seat back i got 6 points in my car just use original rear belt mounting points no problem
I have the DAS, it's a good cage for the money, but doesn't stiffen up the car as much as I wanted it to.
Aribop where did you get the carpet where the seats were? I need to get some for my car.
