993 Forum 1995-1998
1982 911sc sensor plate lever adjustment needed -
Old 01-23-2012, 07:02 PM
groovzilla
groovzilla's Avatar
Received 4,408 Likes on 2,686 Posts
Default 1982 911sc sensor plate lever adjustment needed -
all,
might be adding an aircooled car to my garage and since i know some of you have earlier cars thought you could help....the 1982 911sc i am looking at possibly purchasing has a stripped fuel/air mixture adjustment screw and after a discussion with a mechanic he said i will need a new: sensor plate lever adjustment
anyone have one or know where i can purchase one??
thx
Old 01-23-2012, 07:21 PM
NP993
NP993's Avatar
According to your signature, you've owned a remarkable number of old Porsches -- 22 of them! But you don't know where to buy Porsche parts? What?
Old 01-23-2012, 07:24 PM
groovzilla
groovzilla's Avatar
been out of the later model aircooled loop for a while. thought someone may know a good source for a used part.
any other questions?
Old 01-23-2012, 07:26 PM
NP993
NP993's Avatar
You do appear to be aware that web forums exist...hmmm.....I wonder if those web forums have used parts classifieds? hmmm....
Old 01-23-2012, 07:27 PM
groovzilla
groovzilla's Avatar
time for your meds...you seem sort of cranky
Old 01-23-2012, 07:35 PM
groovzilla
groovzilla's Avatar
...it might cheer you up that i posted a WTB in the classified section.
NP993
NP993's Avatar
http://forums.pelicanparts.com/porsc...s-sale-wanted/
Old 01-23-2012, 08:52 PM
BobbyT
BobbyT's Avatar
You might try a dismantler, such as www.partsheaven.com. They might want to sell the larger assembly, rather than piece it out in the smaller parts, though. I think the part you described is 911 110 939 00, air flow lever arm.
I'd be tempted to drill the existing hole out a bit larger, grind the lower side flat, and JB Weld in a suitable nut. This adjustment screw just raises or lowers the pivot of the air sensor plate arm, so not much force is required.
Old 01-23-2012, 09:05 PM
groovzilla
groovzilla's Avatar
really appreciate the info!
Old 01-23-2012, 09:20 PM
vjd3
vjd3's Avatar
Another source:
http://dcauto.com/
Old 01-24-2012, 02:02 PM
Gunter
Gunter's Avatar
The Bentley SC Repair Manual is a must have and it shows the whole assembly on page 240-19.
I doubt that anyone would just sell the special mix adjust screw or even the lever.
More likely the whole unit.
Good luck.
Old 01-24-2012, 02:43 PM
groovzilla
groovzilla's Avatar
appreciate all the info...thx
Quick Reply: 1982 911sc sensor plate lever adjustment needed -
