At what speed should the rear spoiler rise?
Poseur
Does the 993 spoiler deploy when the engine bay temp reaches a certain figure? I know that the 997 spoilers are also affected by that. (The 997 spoilers go up at 75 mph (actual--not necessarily indicated) and then go down around 51 mph.
I think we need to get a vote on how effective it is on cooling.
Personally, I doubt there can be that much difference. Especially that the engine bay is not really exposed anyway, nor should it be.
Anyone else not a fan of how the 993 looks with spoiler up?
That's what I was thinking, too. Seems that the value of some component in the circuitry simply needs to be changed proportionately. I'd take a swing at it, but I'm completely clueless when it comes to electronics.
It may well be just a case of changing a resistor in the control unit like with the VW corrado electric spoiler.
http://www.corrado-club.ca/mods/oldspoiler.html
anyone good with electrics?
if you look at the spoiler when it is up there's a plastic acordian barrier that gets pulled up.. so that's what shoves air into the engine... not sure how effective it is at cooling (i trust the porsche engineers), but also creats some downforce AND gets rid of the light on the dash
Think it goes up at 50mph and this DIY to dissable the light says so too - http://p-car.com/diy/tail/tailwarninglights.htm
phil.
phil.
pulling the fuse will result in a warning light as the car will see it as a spoiler failure. Disconnecting the control unit will stop the activation, and diable the warning circuit. Plus, it's easier than pulling a fuse. Really.
This is what you are looking for under the pax side dash, with the plug pulled.
^^^Somehow, Ruf found a way to do it, so it must be do-able. Can't imagine that it's a huge deal for someone who knows how the module works.
Pull two pins, cover with electical tape and you are good to go. Spoiler moves only via the ****, and raises by default at 76 MPH (and must be manually lowered).
This mod was created by Garrett376:
Theory:
1. cut the white/red wire (pin 12) to remove the speed signal input to the control module reason: this will disable the automatic raising of the spoiler without disabling the dash switch
2. cut the green wire to remove communication to the central informer to disable the spoiler warning light reason:so that when the speed signal is disabled, the warning won't appear (similar to when the control unit is unplugged in entirety)
It seems that by doing those two simple disconnections, the automatic function of the spoiler will be disabled, and no warning lights will appear, yet the spoiler can still be operated with the switch on the dash.
I'm interested in seeing if it works for you guys? It's worked great for me these past couple of years.
