New project for me, yet another 993 RS Clone for you :-(
#272
Such an amazing build Bob! Thanks for taking the time to document it so well. Much of what you've done inspires me to take mine to the next level. Can't say I'll go this far though.
#277
I referred someone to my post here and I am surprised I have not updated things with pictures of car as it is now. A few mods to controls with dead pedal and fabricated accelerator pedal and CAE shifter in addition to centerlock wheels.
energytrader997 (03-01-2020)
#278
A LOT of win in this thread. Keep up the great work (and the pictures)!
#280
For the center locks I used the factory parts from a SuperCup/RSR 3.8 car. There are two kits one for RSR BBS wheels and one for Cup Speedline wheels. The Speedlines are cast magnesium centered and not available new any longer and older ones have been raced and may have cracks or corrosion issues so I went with new BBS forged alloy CNC center wheels. The difference between the kits lies in the drive pins and central pressure washer for the wheel. The rear kit is straight forward change of the hub and bolting on of the rest of the hardware. The front kit does not use the normal bolt but uses the end of a C4 drive shaft machined for the purpose of holding the parts together - this part is NLA and had to be machined from C4 parts. The reason being that the C4 axle end engages the splines on the hub so the center stud can't turn relative to the wheel. The central bolt replaces the nut on both ends of the car. There is a centering "pot" on the wheel hub that helps support the wheel as it goes on and there are 10 hole options on the wheel to engage the 5 drive pins so wheel replacement is easy. I can R&R all 4 wheels in about the same time it takes me to R&R one not including torqueing the center nut which requires a huge torque wrench, a special grease and 347 ft.-lbs of torque. Of note is all the center bolts are right hand not right and left handed as one would think. The centering pot has splines that engage the hub at specially machined points and the 5 drive pins have recesses machined into the hub for them.
#281
Saw your car at Luft 5. I enjoyed staring at it very much. Great attention to detail.
#283
You are welcome John for the centerlock help. The buttons, lights and switches all come from Porsche race cars past installed in an RS 2.7 lightweight's clock plug. The red and blue warning lights are for the alternator and side marker warning lamps and were first in 908 and 917 cars. The buttons are a starter button and horn button from a 906 and serve the same functions here lower is starter and upper is for horn (although few 906 cars had horns) . The switches are from a 550 Spyder and do the same functions as that car: upper ignition circuit, lower ignition circuit and fuel pump. The red "T" handle battery disconnect is from a 964/993 Carrera Cup car. Note some of the switches, buttons and lamps used in a 917/30 below.
#284
Love this thread! Must be quite a joy to track this beauty!
Any chance you have some pics of your he accelerator pedal that you made up. I’m looking to make a similar unit. Love that it’s so simple and slick.
Pete
Pete
#285
