993 Forum 1995-1998
Help! Lost 2nd, 4th and 6th gear...
Old 10-05-2011, 10:37 AM
Reuben
Reuben's Avatar
Default Help! Lost 2nd, 4th and 6th gear...
My excellent mechanic (Robbie Provost @ Provost Motorsports in Bordentown, NJ) had my car up on the lift this morning and says it's not the linkage, and that I need a new tranny. The present transmission has 145.000 miles on it, with a new clutch about 5000 miles ago.
Anyone have a low-mileage manual transmission they want to part with? Any other suggestions?
All good (and especially money-saving) advice most welcome.
Thank you,
Reuben
Old 10-05-2011, 11:18 AM
trophy
trophy's Avatar
Interesting, I had exactly the same issue while I was at Miller Motorsport Part a week or so ago, was on the track went to downshift to 2nd and got nothing, back to 3rd no issues, tried 4th same problem.
Came in off the track, had a local Porsche expert drive the car, could get it in some times and not others, parked the car, another expert drove the car and it was fine. Really couldn't work out what was going on, the consensus was it was potentially the clutch not fully disengaging in addition to worn out synchro's...
Old 10-05-2011, 11:34 AM
techman1
techman1's Avatar
Reuben, I am not a pro by any stretch, but:
I was talking to a mechanic about shifting problems, and he said internal problems could make shifting difficult. He also pointed out that external problems like the coupler and other things along with engine / transmission mounts.
A shifted trans could cause problems, but just a wild guess. The shop should have already looked for that. I am not sure mounts would cause the 2/4/6 problem!
Good Luck!
Old 10-05-2011, 12:17 PM
Kika
Kika's Avatar
sounds like an opportunity to go G50-21
Old 10-05-2011, 01:48 PM
jscott82
jscott82's Avatar
I would not replace it.. Just get a competent mechanic to re-build it. Its cheaper and you end up with a "new" transmission in the end. Just make sure the mechanic knows what he is doing or send it out to an expert.
I'm betting on a broken shift fork. I had the same thing happen to me, shift fork cracked (you wont believe the crappy pot metal these things are made of) one of the pieces jammed up the whole mechanism.
Old 10-05-2011, 03:14 PM
AOW162435
Seared
AOW162435's Avatar
+1
Andreas
Old 10-05-2011, 03:30 PM
JPP
JPP's Avatar
... and if all else fails, I'm almost positive that RL'r Mongrelcat was offering up a low mileage transmission recently ... forgive me if I'm hallucinating ....
Old 10-05-2011, 04:59 PM
Reuben
Reuben's Avatar
Thank you, all, so far for your input.
I will check out used transmissions. Does anyone have experience with Vertex's rebuilt boxes? they cost around $2200 and come with a one year guarantee. I have also seen a company called BMC&G (Brian Copans) that rebuilds our transmissions. Any other recommendations?
Meanwhile, driving with 1st, 3rd and 5th gear is an interesting challenge....
Reuben
Old 10-05-2011, 05:10 PM
AOW162435
Seared
AOW162435's Avatar
Reuben
Reuben,
Copans is a top-notch outfit. I've taken a 993 transmission to him for a rebuild and the shop is amazing.
Before you go down that road, get your car in the air, remove the tunnel cover, and inspect your shift linkage for deteriorated ball cup inserts or other, obvious, issues.
Andreas
Old 10-05-2011, 05:27 PM
Mike J
Mike J's Avatar
Its sold from what remember (given I did the swap...LOL~!)
Old 10-05-2011, 05:33 PM
os993
os993's Avatar
I have stock gears and synchro's 2nd thru 6th, if you're interested (I re-geared my box in 2001 at 80k miles).
Old 10-05-2011, 10:26 PM
NP993
NP993's Avatar
It's probably a broken shifter fork. Pretty common weak spot on these G50's. Easy repair. Joel Reiser in NY is a top gearbox guy. So is Copans, and Chris Cervelli.
BTW, it's very easy and cheap to strap a gearbox to a pallet and ship it to a competent rebuilder (that is, not Vertex).
Old 10-05-2011, 10:43 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Or place it in a cooler for shipment. I've had a few of them shipped my way for repair/rebuilding.
Might very well be a fork.
Old 10-05-2011, 10:47 PM
Reuben
Reuben's Avatar
Thanks to Noah, Chris, Mike, Andreas and other for weighing in with your advice. I will follow up tomorrow, and pray that it is the fork and nothing too horrendous.
Reuben
Old 10-05-2011, 10:48 PM
ironimages
ironimages's Avatar
Cross Joel Reiser off that list he quit working on cars a few months back, a shame as he was one of the best 993 guys. He is always around and will give advice to anyone who cares to ask, you can contact him through PCA's tech Q&A section.
Quick Reply: Help! Lost 2nd, 4th and 6th gear...
