Recap of the SAI circuit
#346
Super Moderator
Needs More Cowbell
Needs More Cowbell
The use of twisted pair (differential) vs single ended wiring to each O2 sensor would likely have the greatest influence on susceptibility (or immunity).
Wire gauge would impact the routing and ease of use in routing, followed by vibration/damage resistance (if you use very small gauge wire).
The (terminal blocks on the) PCB can accommodate a wide range of wire gauges and single ended or differential wiring to each O2 sensor.
#347
Any Issues for Installed Kits on 97 or 98 Cars?
I may be jumping the gun a bit, but have any of the guys installed their kits on a 97 or 98 car as of yet? Earlier, someone had speculated that the later cars might have different ECU programming logic that would look for different voltage levels in order to determine that the SAI circuit was operating correctly.
Since I won't be installing my circuit until this next week on my 98 C2S, I thought that I'd ask so that if there is an issue, it could be discussed and a solution offered before I install my box.
Any input would be greatly appreciated.
#348
No difference
#350
Super Moderator
Needs More Cowbell
Needs More Cowbell
I would suggest www.digikey.com
They should be able to supply any cable or wire.
If your order is in before 8PM, they ship the same night.
#352
Super Moderator
Needs More Cowbell
Needs More Cowbell
#354
Bought some Cat 5E cable at Home Depot. I cut the connectors off and then pulled back the sheath on the cable and there was no shielding. Just 4 twisted pairs. Can I use this cable successfully, or should I find some that is shielded?
#359
Added: latest additions to 2nd Round List: mcipseric, Richard C2S, eyelasher1, rbettenhauser
Added (by Lewis): latest additions to 2nd Round List (via PM request): jgingera, maestromaestro, ptsheridan
This list for the first round of boards is now closed. I've started a Waiting/Back-up list below for those that missed this first run.
Quick reminders:
1) unless otherwise noted, it's assumed you are asking for an assembled unit.
2) enclosures are optional - feel free to update/ Post a reply/ PM and I'll update the list if you are looking for an enclosure.
Payment Info posted by Lewis (from post #147):
Once assembled, I will start sending PM's so folks can provide me their shipping addresses. Inside the package will be the unit, a hardcopy of the schematic, a hardcopy of the PCB layout and a return address envelope. When you get the unit and everything is OK, just use the envelope to send payment. I am a trusting person when it comes to RL members, so I have no problem sending out the units prior to receiving payment.
Backup/Waiting/2nd Round List
Quick reminders:
- vincer77 - 1
- Rick Lee - 1
- Aircooled Dave - 1
- michaelh993 - 2
- tonypai - 1 + enclosure
- fullbooker - 1 + enclosure
- NP993 - 1 + enclosure
- flying low - 4
- ilko - 1 + enclosure
- 600RR - 2 + 1 enclosure only
- Shahrams - 2 + enclosures
- bw993 - 1
- tbil - 1 + enclosure
- Teddy2 - 1 + enclosure
- Ash - 1 + enclosure
- 993BillW - 1 + enclosure
- Dan V - 1 kit
- efong - 1 + enclosure
- AW21 - 2 + enclosures
- NC TRACKRAT - 1 assembled + 1 kit + 2 enclosures
- cabrio993 - 1
- Paul M - 1 + enclosure
- tropheus - 2 + enclosures
- C4SJOHN - 2 + enclosures
- MDamen - 1
- TheBen - 1
- JPS - 1
- air993 - 1 + enclosure
- alpinadvl - 1 + enclosure
- rsa964 - 1
- cdmdriver - 1
- Jeff96-993 - 1 + enclosure
- Kaefer - 2 + enclosures
- SimonM_98 - 1
- CarreraX - 2 + enclosures
- skypig - 1 + enclosure
- Don't lift - 1 + enclosure
- 2ndof2 - 1
- Richard W - 1 assembled + 1 kit + 1 enclosure
- Amfab - 1 + enclosure
- M Fig - 2
- e3photo - 1
- 911Dave - 1
- kraftsman - 1 + enclosure
- PNogC2S - 1
- CAHRERA - 1
- slapshot - 1 + enclosure
- bpras@msn.com - 2
- Blue TTop - 2 + enclosures
- rdevany - 1 kit + 1 enclosure
- earossi - 1 + enclosure
- sdrake - 1
- cmat - 1 kit + enclosure
- jaguarandi - 1 + enclosure
- Biggdawg - 2 + enclosures
- mike cap - 1 + enclosure
- deekay911 - 1 + enclosure
- helmet993 - 1 + enclosure
- ppressle - 1 kit
- southsong - 1 + enclosure
- V33 - 2 + enclosures
- nels415 - 1 + enclosure
- vr416v - 1 + enclosure
- Don Plumley - 1
- Matt Lane -1 + enclosure
- Jim W - 1 + enclosure
- TxnBluDvl - 2 + enclosures
- mpgandco - 2 + enclosures
- GRINBOB - 1 kit + 1 enclosure
- beagling - 1 + enclosure
- Jscanavan - 2 kits + 2 enclosures
- Richard Lee - 1 + enclosure
- dbog - 1 + enclosure
- bootman30 - 1
- 77'3.6vram - 3 + enclosures
- DryFly - 1 + enclosure
- ESL - 1 + enclosure
- timothymoffat - 2 + enclosures
- suffi - 1 kit
- tom97c4s - 2 + enclosures
- lizSter - 1 + enclosure
- SCMomentum - 2 + enclosures
- elfefan - 1 + enclosure
- deadeye - 2 + enclosures
- FisterD - 4 + enclosures
- rc16 - 2 + enclosures
- tbrom - 1 + enclosure - Please Confirm
- jimbo3 - 2 + enclosures
- skl2 - 2 + enclosures
- mikej - 2 + enclosures
- GC96 - 1 + enclosure
- Cincy_Ron - 1 kit + enclosure
- coreseller - 1 + enclosure
- boostid - 1 + enclosure
- GD993C4 - 1 + enclosure
- Howdy993 - 1 + enclosure
- Mike J - 1 + enclosure
- 996Carrera - 1 + enclosure
- markc123 - 2 + enclosures
- LAT - 2 + enclosures
- Mercedesben - 1 + enclosure
- scphelps1 - 1+ enclosure
- aerocrosby - 2 + enclosures
- rbeggs - 1 + enclosure
- mcipseric - 1 + enclosure
- Richard C2S - 1 + enclosure
- eyelasher1- 1 + enclosure
- jgingera - 1 + enclosure
- maestromaestro - 1 + enclosure
- ptsheridan - 1 + enclosure
- rbettenhauser - 1 + enclosure
Last edited by Ash; 12-03-2011 at 12:26 PM. Reason: added names to Ash's list; received via PM rather than posting
#360
If you have issues with Secondary Air Injection ports being blocked or you want to remove the entire SAI system from your '96 - '98. '95s have the system but the ECU does not check if the system is working correctly.
The blocked ports issue shows up as OBD errors:
P0410 - Secondary Air Injection System: Malfunction
P1411 - Manufacturer specific code
