'95 O2 Sensor
For those in the '95 club, need some help with the O2 sensor.
CEL flashes on then off every once and awhile, and the PPI showed there was a code set for the O2 sensor.
If you did replace the O2 sensor, where did you get it, and the price.
Next, I seem to recall the later cars having 4, 1 before and 1 after cats, per side.
What does ours have? 2, after cats, both sides?
Replacement procedure?
I believe I got mine at Sunset Porsche, Beaverton Oregon. It was several years ago so I don't remember the price but it was probably less than $100.00 (just a guess). The 95 has only one O2 sensor. Below is a link to when I needed to replace mine. It offers lots of good advice.
https://rennlist.com/forums/993-foru...first-diy.html
Perfect link! Waded through a few search results and could not find a '95 specific!
Probably pelican order and put on next weekend.
Thanks for the help!
The O2 sensor on our car is made by Bosch.
The Bosch part number is 0 258 003 369. You can do a Google search on that number and see who has it for the best price.
Ordered one from Pelican recently. Forget the price.
Easy job. Only one sensor on the 95. Sensor is in the midline, kinda beneath/behind the license plate. Install and tighten the new sensor before routing the harness through the clips and engine tin, so you do not twist the wires.
As a point of reference, we sell them for $95.
Bosch #993 606 126 01
Yes, I figured everyone could figure out the part # was a Porsche number. We order under the Porsche part # and that is what is listed on the box. It is a Bosch part. Most Porsche parts vendors will have it listed under the Porsche #. I thought that would be helpful.
Bosch part, Porsche part #993 606 126 01
