Paul902 |
06-26-2011 09:59 PM |
Heilcoil or TimeSert Big Red brake line?
Anyone used TimeSert, Helicoils, etc on the fluid input line of big red fronts? I had trouble removing my brake line and extracted the stuck brake line nut with a drill and screw extractor. I chased the threads with an M10x1.0 tap but the result is that I am only catching 3 and a bit threads, rather than about 5 on the other caliper. The caliper will hold a nut at 20Nm and spec is only 12Nm, but I'm still a bit worried. Have an EZ-Lok on order (like a TimeSert) and thinking about having a machine shop put it in. The outside diameter of the insert is 14.3 mm, and the drill diameter is about 13.0 mm, though, and I'm not sure if there will be enough meat left over on one edge of the caliper. Anyone ever done it? Am I too worried about the 3 threads? Will I ever get my car on the road this summer? Inquiring minds want to know!!
