KW V1 Owners
KW V1 Owners
Hi Guys,
I'll be installing a KW V1 setup on a friends car and then aligning it. A couple questions I have:
Did you install camber plates in the front? I'm only looking for 1.5 degrees max.
Did you install adjustable rear toe arms?
I'm estimating about a 1" drop from stock
I have V3s. I used the stock tophats and with the lowering, was getting greater than -2.0 camber.
I also used stock rear toe arms. don't know how the v1s are set but the recommended range to set the height in the manual drops the front quite a bit - more than 2inches.
