Walrod Bushing Installed: Lessons Learned
+1. Replace "might" with "definitely".
I am seeing a pattern where it makes sense to let the experts do it for you for a fair fee. Recent post about getting a proper set of plug wires from FD vs PITA DIY assembly. Now the bushings on the control arms. I suspect that there are more examples.
Roughly 6 hours from the time I rolled the jack under the car to closing the tool boxes. For me, it wasn't a particularly difficult or technical job. You just have to put your head down and stay with it.
I thought about using Chris' exchange program, but after reading through the procedure a couple of times, it appeared to me that I would gain only a couple of hours max by using exchanges. I had that kind of time to spend, so I did it myself.
It is worth noting that I had none of the difficulties Quadcammer had with his bushings, but I had lined up a machine shop in advance to press the bushings out if it came to that.
Your results will vary...
T
I am thinking about getting the Walrod bushings through the exchange program with Chris. If I am getting new springs installed at my independent do the control arms get removed when they R&R the shocks and springs or is that something extra they need to remove? I was just wondering about labor costs.
quite frankly, yeah it wasn't fun.
I believe $75 to $100
Plus 1. Just swapping out the lcas is no big deal though.
Ryan,
T
T
Ryan,
T
T
a) I never worked on the suspension before
b) Took my time
c) Needed the first bushing to learn how to do it right
it was very rewarding when I accomplished the mission and I met the objective of learning. Chris charges about 200 USD for the exchange which is worth considering because you might need to buy special tools and "waste" a lot of time beside the risk of messing the LCAs up. After having it done once, the procedure would not take me more than 2 hours if I had the new LCAs readily available.
When I heated the hats and removed them, a lot of the bushing came out with them. I think that gave me more room to collapse the remainder toward the center (Just a theory...I have no other experience to compare it to).
That said, I didn't mean to imply that it was easy...There was definitely some heavy duty cussin' a couple of different times, but overall, the job was fairly straightforward....Nasty dirty, but straightforward.
Terry
okie dokie folks. Both sides in and the car is on the ground. Took 2 hours 20 min from out to the garage to wheels on the ground. 2nd arm went much easier than the first as i got my technique down.
Took it out for a test run. car feels nice and solid, steering is a touch lighter and more responsive but didn't get a good chance to really test it out.
That said, I have a slight pull to the right I didn't use to have, so I'll be getting an alignment.
This has to be a walk in the park compared to changing the rear swingplate bushings, rear torsion bars and trailing arm bushings on a 20 year old 911. I don't know where everyone's sense of adventure is.
I concur with e9stibi's logic on the project.
If thats the kind of adventure you're into, you could do ok running an exchange service.
I understand that some like to DIY, and some would rather have someone else do the work. It works fine both ways, as long as one gets to drive the car to get the results of the work.
Just to weigh in here. I had this done to 2 of my cars, a former 964 and current 993. Both times the service was done by RUF Dallas. The first time they put the bushings in themselves. I think they charged me for 2 hours labor just to remove the bushings - they hated it. The second time we agreed to do Chris' exchange program. They charged me for 2 hours to remove and install the control arms.
Chris' exchange program is worth the additional cost if you are DIYing it or taking it to your shop.
I should have listened to you when I had my turbo suspension upgraded at RUF in Dallas. I will need to get this done on both p-cars.
Cheers,
John
I don't think it took us that long, maybe 2 -2.5 hours. This was the third set I replace. The first two sets I replaced the bushings myself. First control arm took 4 hours because I didn't cut the bushing properly. The second, third and fourth control arms took about 30 minutes. There certainly is a time advantage when you get a rebuilt control arm. In every instance there was a marked difference in the before and after performance of the car.
Sorry that I missed you a Cars and Bikes at RAC. I was peddling at the MS150.
Hope your peddling went well and dry at the MS150.
