993 Forum 1995-1998
Marvel's Mystery Oil
Old 02-20-2011, 12:54 PM
Oz-ATL
Oz-ATL's Avatar
Default Marvel's Mystery Oil
Anyone use it? I was speaking with a X Porsche Master Tech recently and he religiously uses it on his '89. Swears by it.
Old 02-20-2011, 01:03 PM
dryadsdad
Team Owner
dryadsdad's Avatar
Received 1,498 Likes on 971 Posts
I've spoken to several professional wrenches who also swear by it. I've never tried it myself nor would I know how to evaluate it.
Old 02-20-2011, 01:52 PM
Ed Burdell
Ed Burdell's Avatar
I've used it in my tractor..
M. Schneider (06-05-2021)
Old 02-20-2011, 01:59 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Its really great stuff!!! Engines that have sat for decades, used it to soak and free up rings, amazing stuff!!
1pcarnut
1pcarnut's Avatar
I'm familiar with the stuff, but uses it how?
Old 02-20-2011, 02:44 PM
beagling
beagling's Avatar
i haven't used it in my 1997 Cab but i do use it in my 1991 Vanagon Westfalia. You put in the gas tank to help clean injectors (1 pint per tankful) and also I put a a couple pints in the oil to help keep my noisy lifters quiet.
Old 02-20-2011, 03:01 PM
Robin 993DX
Lifetime Member
Robin 993DX's Avatar
I was told it is basically automatic transmission fluid.
Old 02-20-2011, 03:10 PM
mike cap
mike cap's Avatar
Most engine guys I know, auto and aviation, swear by it. Especially for older engines that have sat idle. As said above for piston rings and valve trains.
Old 02-20-2011, 03:31 PM
Oz-ATL
Oz-ATL's Avatar
4 ounces per 10 gallons of gas each time you fill up is what I was told. I only drive my car from a few times a month in the winter to a few times a week in the summer so I may start using this keep things lubricated while the car sits. Should help on startups between drives too.
Old 02-20-2011, 03:33 PM
Oz-ATL
Oz-ATL's Avatar
Can also add it as an oil supplement during oil changes.
Old 02-20-2011, 04:17 PM
AOW162435
Seared
AOW162435's Avatar
I dilute it 1:1 with kerosene and use that as my windshield washer fluid. Amazing results!
Andreas
Old 02-20-2011, 04:56 PM
abiazis
abiazis's Avatar
BG products similar to Marvel, but better.......there also is a free protection plan for using their products....see below.....limited coverage, but at least it is something.....
BG Protection Plan Details - Porsche Club lecture showed positive long term effects of their products with a demo showing less friction and wear on parts....and there is a guarantee posted below if you note the use of the product at every oil change....they also make fuel additives and other lubrication additives.......
BG Protection Plan
Lifetime protection for your vehicle!
This document must accompany customer’s copy of Repair Order.
Scope of This Protection Plan
This Protection Plan is separate from, and does not extend the vehicle manufacturer’s warranty. This Protection Plan will take effect only after the OEM warranty expires. However, BG Products, Inc. will pay the deductible amount paid by you under any extended service contract purchased by you which covers such a claim. It is subject to the terms and conditions contained herein.
BG Products, Inc., through its Authorized Claims Administrator, agrees to repair or replace parts of the:
Automatic Transmission listed herein that have been serviced by the BG Automatic Transmission Service and BG 106 and BG 310; or for smaller capacity automatic transmissions, BG 106 and BG 306.
Drive Line Front Differential listed herein that have been serviced by the BG Front Differential Drive Line Service and BG 750, or BG 752.
Drive Line Rear Differential listed herein that have been serviced by the BG Rear Differential Drive Line Service and BG 750, or BG 752.
Drive Line Transfer Case listed herein that have been serviced by the BG Transfer Case Drive Line Service and BG 750, or BG 792.
Drive Line Manual Transmission/Transaxle listed herein that have been serviced by the BG Manual Transmission/Transaxle Drive Line Service and BG 750, or BG 792.
Power Steering System listed herein that have been serviced by the BG Power Steering Service and BG 108 and BG 332, or BG 108 and BG 334.
Cooling System listed herein that have been serviced by the BG Cooling System Service and BG 540 and BG 546.
Engine & Fuel (gasoline) listed herein that has been serviced by the use of BG 110 and BG 203, or BG 110 and BG 208 when engine oil and oil filter are changed.
Engine (gasoline) listed herein that has been serviced by the use of BG 110 when engine oil and oil filter are changed.
Engine (diesel) must use BG 112 in up to 6 quart capacity crankcases or BG 11232 in crankcases over 6 quart capacity.
Brake System listed herein that have been serviced by the BG Brake Fluid Service and BG Brake Fluid. All BG products must be used per product instructions.
Terms, Duration and Extension of This Protection Plan
This Protection Plan is subject to the terms and conditions contained herein:
Plan 1 (0–36,000 miles/0–60,000 km initial service):
The initial service(s) must have been performed within 36,000 miles/60,000 km, as shown on the odometer.
Plan 2 (36,001–75,000 miles/ 60,001–120,000 km initial service):
The initial service(s) must have been performed between 36,001 miles/60,001 km, and 75,000 miles/120,000 km, as shown on the odometer. This Protection Plan will take effect 500 miles/800 km after the first BG Service(s) has been performed by a professional technician.
This Protection Plan for Automatic Transmissions, Front Differentials, Rear Differentials, Transfer Cases, Manual Transmissions, Transaxles, Power Steering, Brake and/or Cooling System will be continued by the performance of the proper BG Service within 30,000 miles/50,000 km of the previous service. One payable claim per service interval is permitted.
This Protection Plan for Engine (gasoline and diesel) and Engine and Fuel (gasoline) will be continued by the performance of the BG Service within 5,000 miles/8,000 km of the previous service. From the date of your Protection Plan enrollment, the vehicle’s engine must be serviced only with the proper grade and weight of engine oil, recommended by the vehicle manufacturer. Timing belt and air and oil filter must be replaced and emission control system maintained in accordance with vehicle manufacturer’s recommendations.
All services referred to in Section A must be performed by a licensed professional service center. You may not change your own oil In the event of a claim, you must provide BG Products, Inc., with satisfactory evidence, according to Section E, that all of the required services referred to in Section A were performed.
A professional technician must perform an approved BG maintenance procedure using proper BG products and equipment. A grace period of 500 miles/800 km will be extended in order to stay within service interval compliance, including initial service.
Covered
Payment of claims under this Protection Plan is limited to the labor time necessary to make repairs or to replace any irreparably damaged parts as allocated by Motor or Mitchell Flat Rate Guide or other industry accepted flat rate guide, multiplied by the commercial repair shop’s posted hourly labor rate, plus the reasonable cost of replaced parts of like kind and quality at the administrator’s discretion.
This BG Protection Plan covers only the lubricated parts contained within:
Automatic Transmission: Covers the transmission housing or case only when damaged by an internally lubricated part covered under this Protection Plan. Items not covered are leaking transmission seals and gaskets; electrical components, such as solenoids. Proper fluids meeting vehicle manufacturer’s specifications must be used.
Drive Line Front Differential: Covers only the lubricated parts contained within the front differential housing or case. Items not covered are the front differential housing or case, pre-packed axle bearing(s), U-joint(s), CV joint(s) and boot(s) unless damaged due to failure of covered part.
Drive Line Rear Differential: Covers only the lubricated parts contained within the rear differential housing or case. Items not covered are the rear differential housing or case, axle(s), pre-packed axle bearing(s), U-joints(s) and CV joint(s) unless damaged due to failure of covered part.
Drive Line Transfer Case: Covers only the lubricated parts contained within the transfer case. Items not covered are the housing or case, U-joint(s), CV joint(s) and driveshaft(s) unless damaged due to failure of covered part.
Drive Line Manual Transmission/Transaxle: Covers only the lubricated parts contained within the transmission case. Items not covered are the case, flywheel, clutch plate, pressure plate, U-joint(s), CV joint(s) and driveshaft(s) unless damaged due to failure of covered parts.
Power Steering: Covers only the power steering gear box or rack and power steering pump. Items not covered are hoses, belts, brackets, seals and leaking gaskets.
Cooling System: Covers only the heater core, water pump, freeze plugs, and radiator. Items not covered are hoses, clamps, thermostats and engine components.
Brake System: Covers only the pump, valves, master cylinder, calipers, and metalized hoses. Items not covered are pads, rotors, shoes, ABS sensors, controller or other electrical parts.
Engine (gasoline and diesel):
Pistons and Rings
Cam Shafts and Bearings
Turbo Bearings
Valve Lifters
Oil Pump
Wrist Pins and Bushings
Push Rods
Crankshaft and Bearings
Timing Chains*
Timing Gears or Sprockets
Rods and Rod Bearings
Intake Valves and Guides**
Cylinder Liners or Bores
Rocker Arms and Pivots
Distributor Drive Gear
Fuel (gasoline only):
Oxygen Sensors
Injectors (Deposit-related malfunctions only)
PCV
*Timing belts and damage to engine parts due to broken timing belts excluded.
**Grinding adjustments excluded.
Conditions and Exclusions of This Protection Plan
If the vehicle odometer has been changed or altered, or if odometer has ceased to function, coverage under the terms of this Protection Plan are not in effect. This Protection Plan covers only legally registered passenger cars, vans, SUVs and pick-up trucks with a GVW of 9,500 pounds/4,300 kg or less. Motorcycles, RVs, and vehicles with more than two axles are excluded. Vehicles used for competitive purposes are excluded. This service excludes in-house maintenance/repair facilities. In the case of a leased vehicle, the lessee must be primarily obligated for repairs and maintenance. If covered vehicle is used for towing a trailer or other vehicle or object, this Protection Plan is not in effect unless covered vehicle is equipped with factory-installed tow package. Vehicles equipped with Continuously Variable Transmissions (CVT) are excluded from transmission coverage. Any claim resulting from collision, fire, theft, vandalism, contamination of fluids, acts of God, misuse, abuse, negligence, damage caused by operation during component failure, lack of normal maintenance required by vehicle manufacturer renders this Protection Plan null and void. Pre-existing conditions, damage to system components prior to the service are excluded and may be verified through independent parts analysis at the discretion of BG Products, Inc. Also, excluded are "Washed", "Branded", Salvage or Junk titled vehicles. To keep this Protection Plan in effect you must keep all receipts and repair orders for maintenance and services required by this Protection Plan. Failure to furnish all necessary records will render this Protection Plan null and void.
Claims and Repair Procedures
In the event of a claim, you must notify BG Products Claims Administrator, c/o Dealers Alliance Corporation, prior to having any repairs made by calling 1-800-848-1660.
You must provide the designated claims administrator with information from all of the following:
All service repair orders as of July 1, 2004, including all applicable BG Part Numbers stated in Section “A,” showing compliance with the terms and conditions of this Protection Plan for each component covered in Automatic Transmission, Front Differential, Rear Differential, Transfer Case, Manual Transmission/Transaxle, Power Steering, Cooling System, Brake System, Engine, Engine and Fuel.
If necessary, all service repair orders showing compliance with the terms and conditions of previous protection plans or service warranties, (excluding OEM extended warranties) and proof of previous plan.
Lease agreement if vehicle is leased.
A complete statement of damage and estimated repair costs.
If required, you must ship the damaged parts, as well as a representive pint sample of vehicle fluid involved with the damaged parts, to:
BG Products, Inc., Laboratory
701 S. Wichita St.
Wichita, KS 67213 USA
BG Protection Plan Reimbursement Terms in U.S. Currency
Engine or Engine & Fuel shall not exceed $4,000 (four thousand).
Automatic Transmission shall not exceed $2,000 (two thousand).
Front Differential shall not exceed $4,000 (four thousand).
Rear Differential shall not exceed $4,000 (four thousand).
Transfer Case shall not exceed $4,000 (four thousand).
Manual Transmission shall not exceed $4,000 (four thousand).
Manual Transaxle shall not exceed $4,000 (four thousand).
Power Steering shall not exceed $4,000 (four thousand).
Cooling System shall not exceed $4,000 (four thousand).
Brake System shall not exceed $4,000 (four thousand).
Engine or Engine & Fuel shall not exceed $2,000 (two thousand).
Automatic Transmission shall not exceed $1,000 (one thousand).
Front Differential shall not exceed $2,000 (two thousand).
Rear Differential shall not exceed $2,000 (two thousand).
Transfer Case shall not exceed $2,000 (two thousand).
Manual Transmission shall not exceed $2,000 (two thousand).
Manual Transaxle shall not exceed $2,000 (two thousand).
Power Steering shall not exceed $2,000 (two thousand).
Cooling System shall not exceed $2,000 (two thousand).
Brake System shall not exceed $2,000 (two thousand).
Old 02-20-2011, 05:02 PM
dryadsdad
Team Owner
dryadsdad's Avatar
Since it was invented in 1923, I doubt this one.
peterp (06-05-2021)
Old 02-20-2011, 05:28 PM
NC TRACKRAT
NC TRACKRAT's Avatar
Andreas
If you're not careful, some poor, gullible soul is going to believe you!
The following 2 users liked this post by NC TRACKRAT:
jay@EZimmoblock.com (06-06-2021), M. Schneider (06-05-2021)
Old 02-20-2011, 05:34 PM
dryadsdad
Team Owner
dryadsdad's Avatar
Originally Posted by NC TRACKRAT
If you're not careful, some poor, gullible soul is going to believe you! ::
Reminds me of a bumper sticker I see at the gym:
"Did you know you old motor oil works well as a lawn fertilizer?"
Quick Reply: Marvel's Mystery Oil
