KriKit V-Belt Tension Gauge Video
I came across this how-to-use your KriKit V-Belt Tension Gauge video on the Dayco belt site. There are plenty of other informative "belt" videos on YouTube...just search on "Dayco belt". These videos can be copied for future reference.
BTW, anyone looking to get one, they're about $20 and you want the KriKit I model (lower tension).
http://www.youtube.com/watch?v=z11wfc-0-hY
So what would be the tensions using this gauge for the belts on a 993? That would be fan, alternator and A/C?
If there is an RS pulley, would there be a different specification?
Cheers,
Mike
Cheers,
Mike
A little tool may not be bad but,............................
Because of variants in V-angle, size, material and design, I rely on feel and lean towards keeping the tension on the lighter side to prevent overloading the bearings.
To insure grip and prevent slippage, I use a little belt-dressing sprayed on a rag and rubbed on the belt while turning the engine by hand.
Commercial belt-dressing is harmless to the material and aids in flexibility.
My personal experience is seeing it used in Industrial applications on a regular basis with good results.
I'd go by the Porsche Technical Bulletin that states...
For a "used" belt that has already been stretched from prior use:
Cold Engine: 15 kg to 23 kg tester scale units.
Warm Engine: 20 kg to 28 kg tester scale units.
The TB discusses the belt tension procedures for new and used belts as well as for the A/C belt.
Last edited by IXLR8; 07-13-2012 at 08:27 AM. Reason: Added Porsche Techical Bulletin
Seared
I used a Krikit gauge once on the 993 belts and found it utterly frustrating. They are automotive V-belts, not mission-critical items aboard the Space Station...
Andreas
That they are not, but there is a reason for bearings going. And when you read about a RLer not being able to install something as simple as a cabin air filter cover, some need all the help they can get; others use a torque wrench even if they are the last ones that need to.
