9m Panelcraft: 993 water leak warning!
#34
I searched and couldn't find my answer but this thread hadn't been bumped in a while and contains some great info and pics for new owners or prospective owners.
Bruce 7 did a fantastic write up.
https://rennlist.com/forums/993-foru...ar-window.html
There was one comment that the windshield might be harder to remove in the future? No experience if that is true or not just read that comment. So combining it with a new windshield install might be strategic, if true.
Anybody pulling out their front windshield corners to dry the channels?
#35
Yes - a known 911 issue from way back. Then again any 15 or so year old car that spent some time in the Northern states will see stuff like this.
#36
I gently pull up the seal of each corner and use a wet/dry vac rather than compressed air. Didn't want to push the water any further into crevices. I wonder what the long term effects of filling the corner void would be, as previously mentioned with silicone? Wonder if doing something like this might actually make things worse by providing a moisture trap.
#37
I've been told that silicone will react with the factory seal and destroy it .. I believe that IF the glass/seal install is done correctly without damaging the paint, then the seal works perfectly.
#38
Please take heed of this advise:
Do not put silicone sealant anywhere near the bodywork of your 993!!!!!
Silicone sealant contains acetic acid which gives it that vinegar smell, when it cures the acid leeches out and attacks the steel of the body. If you must apply sealant to a windscreen use windscreen seal or PU (polyurethane) adhesive only.
#39
#44
I just had both my front and rear windows pulled, and had the rust repaired. Nowhere as bad as these pics, but still required welding in new pieces. Car had the original windows, so it wasn't due to scratching the paint in the frame, and the car was never driven in rain ever. Just something that happens I guess. Ended up costing me $2800 Canadian to fix, not including any windows, just bodywork, paint, and new seals front/ rear.
#45
Basic Sponsor
Yikes!! Those shots are tough to look at.
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
