Shifting problem - hard to get out of gear
Thanks Chris. The car does not lurch forward when starting it in gear. Do you know why this problem only shows up on deceleration?
I will look into just dropping the transmission. If there's anyone in San Diego who has a good setup for this, I'll buy the beer. And not Natural Light, the good stuff like Mickey's.
Interesting, my car has the exact same issue, when decelerating, the car is hard to pull out in gear. Any resolution Psagazio? When accelerating or light throttle, I can flip it out of gear with my pinky. If i'm braking or engine braking, I have to use my hand to move it, clutch pedal all the way in both times.
Seared
As to why the problem appears to change after a clutch bleed - I don't know.
Andreas
It might be compound issue...the splines need to be regreased AND there's air in the clutch hydraulic system. Both would cause "laziness" in disengagement--splines due to increased friction, clutch hydraulics due to air compression.
I have the hard to get out of gear problem also. Most notable coming to a stop in second. Well bled clutch. Have a hard time believing lubed splines are the problem but nothing else has helped. Always a little mystery.
Noodle Jr.
Obviously hoping against the splines but still don’t get why a fresh bleed of the system cures the issue for a while? Going to replace the clutch master before dropping the trans.
