Purchase advice on a sudden wealth of 993's
#47
I spoke with the owner of #3 (he's a fellow Brit expat) a couple of months ago when it was listed for $27,5. At the time he was very explicit about the hard life the car had had at the hands of the previous owner. He said the engine was rebuilt using a used con-rod when the motor seized. Its not a 'new' engine, although the valve guide problem had been addressed. There may be weaknesses in other parts of the motor due to the neglect. Just an FYI.
#49
Well, the PPI on the red cab in Georgia wasn't great. ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
Needs a new rear main seal, new clutch (sooner than later), brake rotors, A/C doesn't work, horn doesn't work, driver's wiper doesn't work, various lights don't work, driver's side door mount check is torn loose, leak in front hood, and the list goes on. The car is certainly not "mint" as described, but I didn't expect it to be. However, I was hoping that it was closer to "very good" than "below average." I know the reduced price may reflect the poor condition, but I'm gonna keep looking.
If the blue one hasn't sold yet, I'll be out there to visit this gentleman in a couple of weeks.
BTW, the PPI was done by a German Car Repair in Roswell, GA (northern Atlanta area). The owner (Alan) was very helpful, spent a lot of time with me on the phone explaining things, made obvious efforts to remain neutral and not try to sell me his repair services (which displayed his integrity), and did the entire PPI without so much as a credit card number. Guess I'm used to NY car shops.
(Don't worry, I sent him the check today.)
As far as PPI's go, I would highly recommend him.![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Next...
Next...
#50
I essentially asked him the same thing and he was forthcoming about that as well, saying "The owner did not maintain the car very well, correct, But any serviceable concerns have been addressed, car is up to spec now and with a new engine, all previous neglect is no longer relevant."
He also iterated the whole list of items that were replaced or repaired, including the piston barrel & con rod, and repaired the crankshaft. I certainly have no qualms about this gentlemen so far. He's been very up front about everything. I'd probably even enjoy sitting down and having a "pint" with him and talking Porsche. I'm sure I'd learn a lot.
Do you have any references on his shop and the quality of their work?
#51
#52
Can't add anything regarding his credentials as a mechanic. From my brief interactions he seemed upfront and straight. All the since-I'm-in-there stuff seems to have been done on the engine. If I remember correctly the plan was him or his wife to keep the car so you'd imagine the work was done right. I don't think you should have too many concerns that the car is not as described.
#53
Hi Teuton993,
When shopping for my first 993 back in April I took the advice of many on this forum and spent a little bit more $$$ and got a lot more car. You'll find that the jump from around $25K to around $35K gets you a car...
1. No stories.
2. 28K miles versus 88K miles ( about 10 years of driving for a lot of us )
3. Rennlist, PCA, or both owned and maybe a concours car to boot. All this versus just some guy off the street.
4. All the toys already installed correctly. For example -- high end suspension, exhaust, wheels, brakes, struts, sways, ovals, etc. ( this list can go on and on )
5. A car that has an extremely tight engine and doesn't burn any oil -- Very important!!!
This is the route that I took and after nine months of ownership I wouldn't change a thing. It's been very nice having a car that always works perfectly and pulls like a train. All for a few extra $$$. Something to think about at least.
George
1. No stories.
George
#54
Thanks for the update CorrdoBrit. Yep, it was supposed to be a car for his wife. If I was building a car for my wife, I'd certainly want it to run well and not have to fix anything on it for a long while. I wouldn't want to hear about it! ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Did you happen to see the car in person? If so, what was your impression?
#55
A good friend of mine is a muscle car collector and he said much the same thing to me last night. And another rennlist member also made a similar comment to me today on the phone. I'm beginning to see a pattern - spend as much as you can afford up front to get the best car you can. I will definitely keep this in mind.
Unfortunately, I'm approaching that limit now.
Thanks!
#56
#57
1 Post
Just a guess. By comparison coupes tend to be owned by a higher percentage of 993 purists and Porschephiles. On a percentage basis cabs are more likely held by a comparatively larger number of top-down sports car afficianados who will move on to an entirely different and newer car at some point and do it more often. I would guess very few if any 993 cab owners here would fall into that category however. For the same reason, the care and attention history of a cab in a purchase decision needs to be possibly even more closely looked at.
#58
Hi Teuton993,
1. No stories.
George
1. No stories.
George
#59
#60
