Electrical 'Whine' through radio - Fixed (Sorta...)
O.k., just had a major service done and now I'm getting a high-pitched electrical whine through the audio system that changes in pitch with changes in RPM. Any ideas what would cause that?
Alternator whine.
Can be solved with a ferrite choke on the power wire to the radio/amp most likely, or improved power/gnd connections (independent connection w/o other things on the same power wire). There are chokes that just clamp on the existing wire.
Strange it started after a svc. What was done? Anything electrical?
Is this something a stereo shop could diagnose/fix fairly easily? I've got a decent one just down the hill from me that does hi-end installs.
My bet is something to do with plug wires.
Once I stuck a little cable clamp thingy on a plug wire to try to get an RPM signal for my data logger, and this is exactly what happened. A whine that increased pitch with rpm. As soon as I removed the clamp it disappeared. I was amazed that a little piece of metal surrounding a plug wire could do that but maybe it was collecting charge and causing some sort of ground loop. It didn't pierce the insulation or anything.
p.s. one thing I've learned when problems like this arise: focus on the things that were worked on. Don't go fussing with your stereo setup in the trunk-- their work was in the engine bay. Probably just a loose plug wire or one that's rubbing against something. Maybe the rotors weren't fully seated.
I had an aftermarket stereo in a former 993. Never solved that darn whine. While I bought that car with the aftermarket stereo installed, I will never go aftermarket in my current car.
I hear ya, it was perfect when I dropped it off on Monday. I'm going to start today with a call back to the shop to look at possible issues. Unfortunately, they are 1.5 hours south of me, so I'll check for loose connections etc. myself and see if there's anything obvious first.
from your line out to amp, I hope you have RCA's, if so....
strip 1/4 inch from both sides of four electric cables.
Unplug each RCA, introduce a bit of one stripped wire between the male and female plug, and plug the RCA back enough to catch the electric cable by the (-) wall of the RCA cable.
Do this for the four line outs.
Now join the other tips of the four electric wires together, and hook those to the radio chassis.
no more whine
no more whine
Here is an outside shot. During the service, did they have to disconnect a ground wire between the chassis and motor/tranny or even at the battery? A missing or poor ground connection could suddenly cause this issue.
Jeff
Jeff
That sounds more probable.... Mine has had a similar issue for a while, still trying to hunt it down. Mine happened after a battery replacement.
Good luck...
Terry
O.k., so I jacked the car up, pulled off the engine cover (yes, I know, I know) and redid the plug connections that I could reach. Did the same from the top to the caps and coils. Started the car, turned on the radio, and voila! BIG IMPROVEMENT! .... however, I still can hear a slight high-pitched whine on some FM stations which I think was there before the service, it's just now I'm paying really close attention to it so it's more noticeable. I stopped at a local stereo install place and the guy said it could be a ground problem so I made an appointment to have them look at it Monday, so I guess more will be revealed....
Thanks all for your input, really appreciate the help.
Sorry for double posting - my Solution to the "acceleration whine"
Wiiiiiii .... wiiiiiiii ..... I took my car to get cleaned and they simply unplugged my RCA FILTER. It was like for months until the whine became too much. I looked under the passenger seat, and simply plugged the cable in.
Done fixed. Hope this helps.
2016
2016
It's always frustrating when something is wrong with your car after taking it to a shop for repairs. Mine came back with no sound from the speakers. After doing a search on this site I discovered that I have an amp under the passenger seat. It was unplugged.
