Hydraulic "Lifter" Anatomy - pics
I wouldn't worry about it until there is an issue.
Luk and INA are part of the same parent company (Shaeffler Group) so I am not even sure if they are any different. They don't even state that Luk makes engine components so it is quite possible that the Luk are re-branded INA lifters.
In any case, I am not sure it matters. Both are OE quality parts.
Here is what's left of my 3 driver's side intake lifters:
The middle one is obviously collapsed, and the seal is gone. It was responsible for the clac clac clac.....
The left one had no seal at all! (Front Intake)
The seal on the right one broke when I pryed the lifter out. (Aft Intake)
I must add that all driver's side exhaust lifter seals also broke in half, when I pulled the respective lifters out of their rocker arms.
The engine has 100000miles, and the car is a 95 c2.
Thanks for posting pictures. Was the clacking loud like a conventional valve out of adjustment or was it a subtle clacking? I haven't heard what a deflated lifter on these cars sounds like. Is it difficult getting the old lifters out? I have a feeling we will all face this at some time.
Addicted Specialist
Edward
The engine was indeed very very loud! It was literally an embarrassing clacking noise.
You could easily tell it was coming from the driver's intake side, and not the exhaust. I went ahead and replaced the exhaust ones just as preventive maintenance. I did the plugs too.
I tried to use a stethoscope to isolate which intake lifter was collapsed, but I was unsuccessful. Anyways, it is such a PITA to get to one of them, that you are better off replacing all three of them at once. I would replace the cover gaskets too.
The engine stayed in, but a significant amount of things had to be removed in order to be able to remove both driver's side valve covers:
1-Left Muffler + brackets (exhaust side access)
2-Left engine tin (allows better access to intake side, and allows torque wrench to be used)
3-Left Heater Blower, and plastic hose (easy on early 95 non-varioram car)
Removing all these is a total PITA. Removing the engine tin is not necessary, but it allows you to use a torque wrench when putting everything back together.
If you strip a bolt, don't panic: hammer a torx 40 socket in it. (Little Know fact: Pep Boys sells the same size bolts and washers.)
PM me for more info on the whole thing.
With 120k on my engine, all my lifters had seals that were deteriorated. The plastic just crumbled when handled. Suprisingly, none were collapsed.
I strongly urge anyone doing a clutch job or fixing a failed lifter with significant miles (90k+) to budget for replacement on all 12. Another while your in there project...
The replacement INAs that I put in 10 months ago did not look like blue seals. They were white if I remember correctly...
When I did my new valve covers a year or two ago, I replaced all the exhaust lifters. Some were a little flat. When I remove the engine and trans to do the clutch and syncros I will do the intakes.
