993 Forum 1995-1998
Headlight Replacement -- easy? Help!
Old Jun 22, 2009 | 10:33 PM
Bonster's Avatar
Bonster
993 whisperer
Veteran: Marine Corps
Default Headlight Replacement -- easy? Help!
Hey guys and dolls . . . got back from a business trip to find that Blupurr has a headlamp out. Is this an easy fix? Looked in the Essential Companion and did not get enough of a look. I don't know if this is Litronic or not . . . but does that matter? Can someone help me DIY this? I rarely drive at night, but at the moment, when I do, I'm running on highlights. TIA,
Oh . . .PS . . . in the glove compartment I found a couple of spares . . . part number is H I D Series H1 ~ does that help? TIA again,
Old Jun 22, 2009 | 11:18 PM
Bob Rouleau's Avatar
Bob Rouleau
Still plays with cars.
Bonnie, it's been a while since my 993 but I am pretty sure you simply change the bulb from the back of the lap housing. I recall it was not big deal to do.
Old Jun 22, 2009 | 11:26 PM
TMc993's Avatar
TMc993
Takes about 10 minutes start to finish. If you have an owner's manual, the process is described there. If you don't have a manual, shoot me a PM and I'll take a few photos of mine and send them to you. Also, if you search under "headlight" and specify "Search Titles Only" you will have a plethora of threads that describe issues such as what bulbs to get, etc.
Good luck...
Old Jun 22, 2009 | 11:28 PM
Bonster's Avatar
Bonster
993 whisperer
Terry and Bob . . . THANKS! Yes, I do have the owner's manual. Who'd have thunk to look there, lol. I could use those pics anyway, just for help. Send them (Terry) to bonni at weatherwax dot net, please. THANKS again!
Old Jun 23, 2009 | 12:34 AM
Kika's Avatar
Kika
sounds like a good time to upgrade to HIDs!
Old Jun 23, 2009 | 07:38 PM
Pete Lech's Avatar
Pete Lech
Lifetime Member
Sounds like halogen bulbs, but the same goes for HID bulbs:
Don't touch the bulb with your fingers, as the oil from your hands could lead to early failure.
If they are Litronics, it may not be the bulb, as there are 2 other parts to fail. My igniter failed. You will find a silver box underneath the trunk carpet on the inside of the fender
Old Jun 23, 2009 | 10:49 PM
nshanny's Avatar
nshanny
How hard is it to upgrade the standard headlights to HIDs? I have hunted around and found a bunch of different options, but curious as to the actual work involved as well as cost.
nick Shanny
Old Jun 23, 2009 | 11:22 PM
TMc993's Avatar
TMc993
EDIT: The photos are in your mailbox.
Bonni,
It was a "long day at the office" today...I'll get the photos out tomorrow.
T
Old Jun 23, 2009 | 11:59 PM
Blaine S's Avatar
Blaine S
Bonni - be sure and use a large towel or microfiber cloth to protect your fender when you remove the headlight assembly.
Nick - there are a couple of us here just a bit west of you that could help if you decide to DIY. It is one of the best bang-for-the-buck upgrades there is.
