993 Forum 1995-1998
Rear center reflector--unused bulb sockets?
Old 07-26-2009, 06:19 PM
curve lover
curve lover's Avatar
Great idea & info here. I'm all about keeping others from merging with my paint.
Originally Posted by ilko
I turned mine into additional brake lights:
I did the how-to here: http://web.mac.com/ilko/RSA/How-To/E...light_mod.html
Originally Posted by d964
Thanks to ILKO, I did it too. I love that MOD!
Originally Posted by skywachr
Having an added brake light would be a great mod for those who have the third brake light setup (basket handle) and have thought about removing it.
Important pre-modification step for those with pre-owned Porsches: have someone else activate your brake lights for you / take a photo, etc.
You may be as thrilled as I was to realize I owe the previous owner big thanks for already doing this mod!
Old 07-27-2009, 03:30 PM
Jeff96-993
Jeff96-993's Avatar
I'm planning on doing this mod soon. Based on the input here I'm confused whether the brake light harness is already there, or if I need to procure one?
Old 07-27-2009, 04:41 PM
ecobb993
ecobb993's Avatar
Jeff,
The wiring harness is there for the existing lights, but you'll have to tap into those wires to connect the new bulb sockets. Hope that helps.
Old 07-27-2009, 05:39 PM
Jeff96-993
Jeff96-993's Avatar
Thanks JC, I'll start digging into it soon.
Old 07-27-2009, 08:17 PM
FlatSix911
FlatSix911's Avatar
Originally Posted by ecobb993
Jeff,
Does anyone have a photo of the wiring harness mod?
Old 07-27-2009, 08:52 PM
Raptor
Raptor's Avatar
ilko: Many thanks for the post. Great Mod. Anyone thinking about using super bright LEDs?
Old 07-28-2009, 09:34 PM
Blaine S
Blaine S's Avatar
Here are the differences between the original ROW center reflector where all the sockets are used (993 631 130 00 ECE) and the US version with the plugs (993 631 140 00 USA).
I have a new ROW version with factory wiring for sale but it has a chip missing from one corner. Also, the ROW version that I have does not have the small extensions on the ends that help fill the gaps between the center reflector and the rear side markers. They may be missing from the factory or somehow they broke off. I'm not sure at this point.
I also have a used USA version that leaks (replaced with a new one) if somebody wants it for parts or a cheap track part where you don't care if there is some condensation in it after it gets wet.
Retail price on these is around $400. I'd take a fraction of that considering the condition (chip'd euro or leaky US), but something fair.
Old 07-28-2009, 11:38 PM
FlatSix911
FlatSix911's Avatar
Blaine, thanks for the excellent photos of the ROW and USA center reflector versions.
Can the US version be used if the plugs are removed and new bulb sockets are inserted like the ROW center reflector where all the sockets are used?
(I assume I can tap into the existing USA wiring harness and add the sockets)
Old 07-29-2009, 08:37 AM
Blaine S
Blaine S's Avatar
Can the US version be used if the plugs are removed and bulb sockets are inserted like the ROW center reflector where all the sockets are used?
I think you would have to tap into the wiring connector (violet colored in the pic) on the US reflector to add the additional bulb sockets. If you wanted to use donor parts from a second US version you could probably do it.
You can see in the pics of the ROW version how all four bulb sockets are wired into the single connector.
Old 07-29-2009, 09:18 AM
Uber 911
Registered User
Uber 911's Avatar
Quote: I have a new ROW version with factory wiring for sale but it has a chip missing from one corner. Also, the ROW version does not have the small extensions on the ends that help fill the gaps between the center reflector and the rear side markers.
ROW do have extensions http://www.design911.co.uk/fu/pt70_6...flectors-Rear/
Old 07-29-2009, 10:12 AM
Blaine S
Blaine S's Avatar
993 631 130 00 ECE wired with fogs does not. Anybody ideas?
Old 07-29-2009, 08:43 PM
Jeff96-993
Jeff96-993's Avatar
Based on the pics, the harness for the extra lights isn't there. Can't wait to pop it open tonight and check.
Old 07-29-2009, 10:12 PM
Jeff96-993
Jeff96-993's Avatar
Nope, no wires, so I'll be off fabricating the harness and acquiring some bulb sockets.
Old 07-29-2009, 10:36 PM
Dudley
Dudley's Avatar
Wow Blaine. great photos. That new Kodak Instamatic is really paying dividends.
Old 07-29-2009, 10:37 PM
Barney1
Barney1's Avatar
let us know what sockets you use please..
Quick Reply: Rear center reflector--unused bulb sockets?
