Optima Red Top not holding charge
My Shumacher smart charger indeed uses a different routine for AGM / gel batteries compared to regular batteries. Perhaps this could have been hurting my red tops, since I use "regular" charging. (interestingly, my "regular" charging still seems to fall within Optima's recommendations of 13.8 to 15V)
I need a battery that's basically "install-and-forget", and compatible with a standard battery tender. I ran across the info on the different requirements of charging Optima's as my second on was in its death throes. At that point, I decided a 'standard' battery was the type for me - especially factoring in the price difference.
A 4-5 year life span doesn't sound all that impressive to me. Any battery, unless it's severely abused, should do that.
It was my understanding these batteries are a paste surrounding thin spiral coils.
I've done some internet searches for the right kind of charger based on the info in this thread (Thanks to all). From what I can tell in looking at several sites, no cig charge anymore. Am I right? No big deal, but it is convenient.
chuck
chuck
I've stayed away from Optima batteries because of the variability of results people get with them...With an Optima, everyone seems to have a different story.
I've found that for my driving habits/conditions, nothing beats an Interstate battery for "install and forget" service. They're not that expensive and for me at least, give great service over a long periods of time.
I really don't like the Optima batteries, having gone through two in a short period of time.
I'm using the OEM Bosch battery in my 993. It was relatively inexpensive, properly vented. I'll stick with what the Porsche engineers had in mind...
Just curious, folks...Those that said they have a battery cut-off...When close to inspection time, aren't you concerned about getting a "fail"? FWIW, I use the Battery Tender Plus and have gotten excellent results with it on OPTIMA, ODYSSEY and conventional maintenance sealed batteries.
Guest
Posts: n/a
With all of the other reported problems with Optima batteries, I'm going to assume that it's my battery and not my charging system that's causing the problems. I just ordered a CTEK 3300 with the cigarette lighter adapter and this should keep me running.
Thanks to all
Thanks to all
FWIW, I have large gel batteries in the sailboat. In the operation manual, it states that under no circumstance should the charge drop below 65% as damage will be done to the unit.
I have a solar panel to keep them at 100% while I am not in attendance.
In the Pcar, I always used a Pcar trickle charger to keep the gel battery charged. Never had a problem.
Good luck
Good luck
I still have the Optima red top that came with my car when I bought it over 4.5 years ago and it is still going strong. First few Omaha winters I let the car sit with no trickle charge. Sure, battery would be dead come spring but after a charge with my Craftsman charger it was good to go for the season. Can't say this practice worked for my Ducati as I had to buy new batteries every year. This past year I was out of country for over a year so I bought a Battery Tender and hooked it directly to the battery. My wife drove the car maybe once while I was gone and she had no problems. When I came back in Aug the car was good to go. Am I just having extra good luck with this battery?
And thanks to you. I missed the cig lighter attachment for these units when I searched. Adult ADD.....That's my excuse.
What i do not understand is why one would choose a Red top instead of a yellow top for a non diesel Porsche . . .
But after having tryied the odyssey i am not returning to Optima red top as i have had quite a few of them die on me.
The Yellow top has proven to be more stable.
And as for chargers i use nothing but Ctek for trickle charging my batteries
OTOH, Red tops seems to have a real problem when not daily driven, so the yellow top probably couldn't be any worse.
