993 Forum 1995-1998
Where and how to mount rear canisters for remote reservoir shocks?
Old 11-25-2008, 04:23 PM
TheOtherEric
TheOtherEric's Avatar
Default Where and how to mount rear canisters for remote reservoir shocks?
Edit: Problem Solved, update in post #26.
I'm hoping for some advice on mounting the rear canisters for JRZ or Moton shocks. Some people have drilled huge holes in their cars to get the cans through (pic below) but I don't want to do that. A couple alternatives seem to be:
1) Have quick-disconnects installed in the lines so that you can drill a smaller hole in the car;
2) Push the can up thru the big hole in the center of the seating area. Dunno if this is for real.
3) Install cans in the engine bay. Not sure how you route the lines up though.
Sample pics of (a) huge hole that I want to avoid, and (b) quick-connect in a non-porsche:
Old 11-25-2008, 04:49 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Go Staubli for Q/D's if you go this route - they are the best!
Old 11-25-2008, 04:51 PM
viperbob
Former Vendor
viperbob's Avatar
#2 with quik disconnects. Don't tell anyone, but I have removed all the nitrogen pressure from a non-quick disconnect shock and then the reservoir and just routed the line through rubber plug in the bottom back part of the rear seat well. Reconnected and installed pressure. You MUST make sure you do not spill any of the shock fluid (essentially just motorcycle hydraulic fluid). In front, it is connected to the strut brace. You will need to slot a small channel for the hose so it is not pinched by the camber plates.
Old 11-25-2008, 06:18 PM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Eric,
QD's are the way to go here.
I've done what Bob did and found air in the shocks when I went to check them later so if you disconnect the lines, be prepared to bleed them on the bench.
I've ordered QD's on 993 Clubsports but it adds to the cost, as I'm sure you know. Usually, I just put them on the rears since the front struts can be installed and mounted without disconnecting anything. As Bob said, you simply need to slot the Camber Plates a bit.
Old 11-25-2008, 06:39 PM
TheOtherEric
Sounds like QDs are the way to go. Is that something most rebuild shops can easily retrofit? I'd think they'd need new lines too instead of just the fittings.
Hmm. Do you slot the camber plate or the car?
Old 11-25-2008, 07:22 PM
You need new lines with the QD's installed in them. Then, the shocks must be bench-bled.
Slot the car AND the Camber plate.
Old 11-25-2008, 08:21 PM
Gasser
Gasser's Avatar
Whats wrong with leaving them in the engine bay? I have mine mounted at the front of the engine compartment where they are easy to get to. They never seem hot as there is a lot of air flow there. Car handles Awsome. They would be harder for me to get to in the back seat area. I don't care if anyone can see them.
Jeff
Old 11-25-2008, 08:32 PM
CWay27
CWay27's Avatar
I would leave the cans in the engine bay like Jeff has noted. It sure looks cool when they are mounted on the roll bar but who cares really.
Old 11-25-2008, 09:12 PM
Mark in Baltimore
Mark in Baltimore's Avatar
Eric,
As you probably know, I have mine mounted in the engine compartment. I think they are probably better positioned in the car itself, though, and always lift the engine lid after a run to keep the cans cool. That said, having the cans in the engine compartment has not seemed to slow me down or adversely affect the handling.
Old 11-25-2008, 10:33 PM
RickBetterley
RickBetterley's Avatar
Assuming that there is more heat in the engine compartment, do you think that heat might lead to more wear on the components of the can?
Old 11-26-2008, 12:54 AM
TheOtherEric
Yikes, I just read somewhere else that the quick disconnects & lines are like $200 to $300 per side. Ouch.
Mark - your solution is sounding better.
Old 11-26-2008, 01:20 AM
chris walrod
Guru
Rennlist Small
Business Sponsor
And the Staubli's are even more than that!
Old 11-26-2008, 09:01 AM
MB965
MB965's Avatar
I have my Moton rear reserviors mounted in the engine compartment just above the engine on the bottom side of the rear shelf.
I do not have the heater fan so there is room. Locating the right side was tight but I am able to access the adjuster and can easily get to the nitrogen fill valve.
I positioned the reserviors when the engine was out (to get the hose past the engine shroud), but I drilled the mounting holes with the engine installed.
The fronts are mounted on the strut brace with the car and camber plates slotted.
The reserviors never even get warm after a 45 minute track session.
I will post a few photos when I get home tonight.
Mike
Old 11-26-2008, 10:24 AM
TheOtherEric
Great comments guys, thanks. Mike - pics would be very much appreciated.
Old 11-26-2008, 10:53 AM
Mark in Baltimore
Eric, I should clarify that my rear cans sometimes do get warm if I forget to lift the lid after a session. However, even on the hottest days, with all of the air moving around, they remain cool immediately after a run
Quick Reply: Where and how to mount rear canisters for remote reservoir shocks?
