OE Shocks?
OE Shocks?
Hi guys,
The car as purchased March 2008 :
- NA 1997 C2
- Zenith Blue Metallic/Midnite Blue partial leather
- 34k miles when new-to-me, now ~ 38.5k miles
Mods:
- H&R lowering springs (purchase documented, not install), lowered to RS spec. (as I measure)
- 18" Technology wheels (hollow, not documented), replaced opt. 17" Cups
- Sparco seats (model?, not documented)
- Clear Bra (documented)
The PPI that was performed prior to me buying the car stated that the Shocks were "OE (Bilstein Green)" and the Performance was "good".
I thought that the NA 993s came from the factory with either Monroe or Boge shocks. Is this correct?
What are Bilstein Greens, and could they have been OE?
It also seems odd that a PO (I'm the fourth owner) would install the H&Rs, but leave the shocks OE.
Thanks for any help with the OE shocks
Gary
- NA 1997 C2
Mods:
Gary
Don't know... Bilstein's colors are Blue & Yellow. May be after a while the colors mix up together which would make the schocks green
If these "Bilstein Greens" are not OE, and were put in when the H&Rs were, they are probably 8 or 9 years old. Maybe Bilstein made a "green" back then.
Gary
I can't remember if Bilstein changed their colors over time. May be somebody with more memory than me will chime in, hopefully.
The Monroes are green and at 37K they are shot. They generally don't leak but the internal valving gets clogged/gummed and the fail to dampen. I changed mine out at 27K and they were clearly shot.
Hopefully by the spring this economic downturn (crash?) will have recovered at least somewhat, then I'll most likely just put in Bilstein HDs.
Thanks for the reply
Hey Chris, that's pretty funny . Do you think that shock came out of a running Porsche? Must have had pretty bad bounce and float!
In a 993 with H&Rs installed, can you use the old test where you push down on the front end and check for bounce?
Thanks,
Gary
I did not have bounce or float either - I had a harsh ride (clogged valves = no fluid transfer = harsh ride)over bumps which is now a lot smoother. Good luck. BTW, a shock DIY is not bad at all.
My ride does seem kinda harsh. The HDs go in next spring!
Gary
I too wasn't convinced that the stockers were shot at just 30k miles. We'll after installing PSS10's I now know the truth. Harsh ride with slight vibrations after each bump. The doors seemed to rattle, windshield creaked, cab top frame rattled, not constant but just over the normal bumps. Now the car feels solid and I just thought it didn't bounce or float.
Gary
Yes! The car now feels like a new sports car. Stiff ride but but the dampened. Much more solid and controlable than before. IMO anyone who thinks 10 year old stock shocks arn't worn out are kidding themselves!
