Factory radio swap - CR-1 to CR-210
OK the 1995 cab I just bought has the:
CR-1 (radio) with the CDC-1 (CD changer) setup.
The question I have is, it a direct plug and play to upgrade to a CR-210 that I have sitting in the garage? Also, if the CR-210 is a direct replacement will it work with the CDC-1 changer that is precsently hooked up to the CR-1?
If it helps the car was produced in 05-94 (eary build)
TIA
Mike
TIA
Mike
CR-1
I tried to do the same thing the CR-1 has a different connection than the CDR-210. Don't cut the wires I hate that! Try to find an adapter that fits your new radio, try SW Stereo they have them. Also, are you going to sell your CR-1 if so I pick it up from you.
I will call them. I will let you know on the stereo once I get it installed. probably will be in month or so. I have a lot of work to do on the car.
mike
mike
