Part Number for Console
Can someone with a PET please give me the part number to the console that is forward of the shifter in our cars? I dont need the inserts that house the switches, just the complete console...as pictured below: TIA!
I am checking it right now and for once I find hard to figure it out.
- 964 552 017 00 says it's for center console upper part in leatherette code 05T for black. But it shows for the entire console from front to back.
- 993 552 013 04 says it's for center console for cars with airbag lower part carpet. This part looks like the black console behind your switch panel and cuby. The way I see it, this would be the piece like shown in your picture.
Ok I think I get it now..... The console in your picture is usually covered in carpet and not bare plastic. It confirms the 993 number. If you need both little cover doors on each side, you will need the following;
- 993 552 525 00 for driver side (code is 01C for satin black by default)
- 964 552 133 00 for passenger side (code 5FV for black)
Thanks CWay27...hmmmm...all I need is the part forward of the shifter that holds the switch panel and cubby. I'll call Sunset tomorrow and see what they come up with.
Yes, you are correct, but I am speaking of the actual console that holds the cubby and switch panel....the biggest black piece that runs forward to the firewall under the dash.
