Is a 964 faster?
Escapee
This may be a long shot but here it is...
A 964 on a cold day when the air is very dense has more punch than a 993 on a hot day. I have experienced this on many occasions with my 993. The difference in performance is extreme from one air temperature to the next. In addition, if the 993 was running the air conditioner and the 964 wasn't during your ride, that could easily account for the noticable perfomance difference in favor of the 964. These cars are close enough that operating conditions will favor any one over the other.
Having said all that, everyone knows that a silver colored 993 will always trounce a 964 all other factors being equal!!!
I have not actually compared the numbers, but my chipped c2S Cabriolet feels faster than my c2S. I don't know if it's the weight of the c2S over the 964 or perhaps the altitude in Colorado, but the 964 feels faster. However, I do agree, that the 993 is much more refined and a better driver by far than the 964. Yet, the C2 Cab just has that nostalgic feel to it. Got love them both for different reasons.
______________________
90 C2 Cab
97 C2S
91 Ferrari Testarossa
01 Lamborghini Diablo 6.0
90 C2 Cab
97 C2S
Thanks for the posts that were constructive and did not use the word "troll." I know the specs, I know the cars. I have some seat time as driver and passenger in both and the 964s seem to accelerate a lot harder in the first three or so gears. I have looked at old articles etc and seen some that say the 993 hits 60 in 5.2 or 5.5 and the 964 is 4.9. Then I asked around some and was told the 6 speed robs the 993 of a lot of potential due to the tall gears. Seems odd - I would think they would be shorter since there is one extra.
I like the 993 more overall but I am torn because the 964 seems to have more punch. And I wondered if anyone else feels the same way or if I am just mistaken.
I asked in here because I knew the 964 group would agree of course.
just some stuff I found ....
The first 964s available in 1989 were AWD equipped "Carrera 4" models, Porsche added the rear wheel drive Carrera 2 variant to the range in 1990. Both variants were available as a coupe, Targa or Cabriolet. The 964 Carrera was the last generation sold with the traditional "pop top" Targa roof. Later evolutions of the Targa, starting with the 993 generation, replaced that setup with a complex glass-roof "greenhouse" system. A new naturally-aspirated engine called the M64 was used for 964 models, with a displacement of 3.6 litres.
[edit] Engine
Engine design: Air/oil cooled, horizontally-opposed, dry-sump lubrication, rear-mounted
Engine displacement: 3600 cc (220 cu in)
Cylinders: Six, light alloy head
Bore and stroke: 3.94 x 3.01
Compression ratio: 11.3 : 1
Fuel/ignition: Electronic fuel injection, DME controller, with twin-spark with knock regulation
Crankshaft: Forged, 8 main bearings, enclosed in light alloy case
Valve Train: Overhead cam, one per bank, double chain drive
Power: 184 kW/247 hp (SAE net)/250 PS (DIN) @ 6100 rpm
Torque: 310 N·m/228 ft·lbf @ 4800 rpm
Engine speed limitation: 6700 ±20 rpm
[edit] Performance
Top speed: 162 mph (261 km/h), 159 mph (256 km/h) (Tiptronic)
0-60 mph: 5.5 s (manual transmission), 6.2 s (Tiptronic)
1/4 mile: 13.6 s (C2), 14.0 s (Tiptronic), 14.1 s (C4)
Co-efficient of drag: 0.32
Fuel consumption approx 24 mpg[vague]
[edit] Selected dimensions/capacities
Curb weight (to DIN 70020): 3,031 lb/1,375 kg (C2); 3,100 lb/1,406 kg (Tiptronic), 3,252 lb (1,475 kg) (C4)
Wheelbase: 89.4 in (2,270 mm)
Overall Length: 168.3 in (4,270 mm)
Width 65.0 in (1,650 mm)
Height: 52.0 in (1,320 mm)
Front Track: 54.3 in (1,380 mm)
Rear Track: 54.1 in (1,370 mm)
Ground Clearance: 4.7 in (US)
Fuel Tank: 20.3 gal (US)
Engine Oil: 20 L (21.1 qt US), oil change volume: 9 L (9.5 qt US)
Transmission Fluid: 3.6 L (3.8 qt US) (C2), 9 L (9.5 qt US (Tiptronic), 3.8 L (4.0 qt US) (C4)
[edit] Engine
[edit] Performance
I have been on the track...
with some 964 cars...I can't pull them in a drag race. Regardless, cosmetically, I love my 993....but a clean 964 RS America is a sweet little car. And a 964 Cup Car...brutal...but also very expensive.
C2S Cabriolet ...
Jeff,
I wish I had a C2s cab. I saw one from the special wishes come up for sale last year, as I recall. I think no one even knew that a few were made. But it was all original. It looked amazing.
Alex
90 C2 Cab
97 C2S
Alex
90 C2 Cab
97 C2S
I read some stuff here about cam timing on 993s being dodgey compared to on a 964 and it accounts for a lot of 993s being down on power. Some stuff about one mechanic who said a he sees tons of 993s he with incorrect timings that are way down from where they should be in power. Maybe it's more common for a 993 to be a little off. Who knows. I still like a 993 more.
They said you could set your timing right and get back to factory spec in HP but to make it where it lasts a long time you could retrofit a doohickey from the 964 onto the camshaft of the 993. The part actually came on early 993s and it allows better adjustment. Forgot the thread here but search for cam timings.
I'm ashamed of muself for dignifying the o/p w/ an answer but
some facts
from Auto,Motor & Sport
model, 0-100kph, 0-160kph 0-200kph standing 1km,top speed mph
964C2, 5.5, 12.9, 21.3,25.0, 164
964RS, 5.3, 12.2, -, 24.4, 161.5
993C2, 5.2, 12.4, 21.1, 24.7, 166
993RS, 5.1, -, 14.7, -, 172
some facts
But to the real world (or real race track) point, as Martin said..........and I've been on both ends numerous times..........993 v. 964 whether it be Sears, Laguna, Thunderhill (god forbid Buttonwillow)..........it's MAYBE a car lengths difference on any of the front straights.
Frankly, I think it depends on what 993 and 964 you're talking about. I have a fairly well modded 993 C4S with chip and short-ratio box. Last year, I did a group canyon drive with PCA and was driving behind an RSA with headers, cat-bypass and high flow mufflers (makes a big diff on 964s). I was very surprised at how hard that thing pulled at WOT. That said, I doubt a stock C2 964 can keep up with a stock C2 993.
