Car Hifi Question: Wining Noise via Aux Input while Charging
I hooked up a Dell PDA to my CDR 220 via Becker aux input cable and experience wining noise that follows the engine revs. This happens only when I supply the PDA with 12V power from the car. On battery, it is silent. it appears that my power supply is not "clean".
What is the best way from your experience to supply an aux input device with clean 12 V?
Thanks,
Erik
Thanks,
Erik
Ground loop most likely, get a ground loop isolater. David NAvone sells them on his website, or try an electronics store, like radio shack, Fry's etc...
Try and ground to metal and not an existing ground, might help. Ground fault isolators are cheap and will remove a lot of noise. But, its a ground that is causing the whine. Does it get worse when you rev the engine?
Bad ground. Try a ground fault isolator, can get them from radio shack. You can also buy a suppressor that mounts on the alternator mounting bracket, that will suppress noise from the alternator and cut out the whine as well.
Check the grounds first, make sure its metal to metal and if you can, put it on a separate earthing point.
I have this very slight whine on my Ipod even with a GFI.
Hi Eric
Here's a good description of the problem http://www.carstereo.com/help/Articles.cfm?id=71
Chris
Chris
