ANYTHING NEW ON THE MOBIL 1 FRONT?
#93
I'm curious, the last recommended oil TSB I saw stater 0w40 was the recommended weight. Has this changed again? The latest "Engine Oils Approved by Porsche" I have is dated Jul 28, 2006 and all the oils on it are listed as 0w40 or 5w40.
I'm not denying that a 50 weight wouldn't be better I'm just curious why the dealer would be dispensing 0w50 when Porsche recommends 0w40.
#94
Well, the one thing that I have learned from this tread is that I am going to ditch the Mobil 1 0w-40 fill that is currently in my 993 (only 3k mi ) and refill it with Elf Excellium Racing 10w-50. Sorry, if it is good enough for Porsche Motorsports, it should be good enough for me. And it is synthetic. In the end, both of those things make me feel good.
#95
I am having my car filled this week with M1 0-40W (or it has been already been...)
This was on the basis on the last oil thread in October which basically threw out M1 15-50 as the No.1 oil for aircooled, and suggested, M1 0-40W as one of several ideal replacements.
Charles - I looked up on the Mobil site the ZDDP of M1 0-40 and it was 1000ZDDP. On your site I think you suggest that this ZDDP is lower than the reccoemended levels of ZDDM for our aircooled cars (1200-1400ZDDP?), but that this can be resolved by using an oil additive such as GM's EOS, which will boost the ZDDP, by 100-200 ZDDP.
Did I get this right? Do I need to do this and if so have I rectfied what's lacking in this oil?
There seems to be some differing opinions out there, and to be honest I am sure I am one of many wondering what the ideal oil is... that won't lead to the premature engine wear that steve has noticed is on the increase. I seem to be hearing that this is now: Brad-Penn 20w-50 ?
Phil
Phil
#96
RL Technical Advisor
#97
But if my engine feels good I feel good
After reading all of the posts and the 400-500 at Pelican I think my suggestion for an approved oil list looks even better. There is obviously a substantial level of concern with the change in oil formulations and the same questions keep getting asked. The only issue is who (or whom?) will approve the list. I think it's like belling the cat
Obviously Steve and Charles are the most qualified folks that I know of due to their experience and testing. I doubt Porsche takes much interest in the air cooled cars these days as they are focused on the new stuff.
ps This oil issue is not just for Porsches. My background is muscle cars and there have been many stories of wiped cams. It seems to mainly apply to rebuilt engines. I suspect higher valve spring pressures and low quality lifters might have something to do with it too. I went as far as using a roller cam to avoid this problem altogether. Hughes Engines issued a publication specifically talking about the reductions in phosphorus and zinc levels just like Charles has.
#98
+1 Agree. Lets make it a sticky too.
Agree, plus there are some other Oil experts out there that might want to opine also ....
#99
Good thread... does anybody know the ZDDP level for this oil?
Elf Excellium NF 5w40. More info:
Spec sheet is here (download was not allowed, sorry):
http://www.finalube.com/Product_Data..._Data_Main.htm
I buy it directly from my shop, but a quick net search shows it can be ordered.
SL/CF, recommended for "vigorous" driving.
#100
I'm so confused...the (important) factors presented here seem to be viscosity, ZDDP level, syn vs non-syn, and detergents. Swepco 306 and Brad Penn oils are getting the approval and M1 is eating dust. However, when I look at the test data on Charles' site (downloaded an Excel spreadsheet), I think it suggests that even M1 SM formulation 15W50 has higher Z and P levels than Swepco 306 and Brad Penn, plus it is synthetic. Is it down to the detergents?What am I missing??
Thanks for the informative posts!
#102
It's in the Blend
Charles, my RL 15W-50 says it meets the ACEA B5-02 and A5-02 requirements...I haven't seen those ACEA numbers before...just the A3/B3 as you previously noted. Are the B5/A5 newer more rigorous testing protocols?
#103
Its the single best thing one can to do to extend engine life based on what I've seen in automobile engines since 1962 and 911's are no exception. Man, I feel old,...
#104
#105
Shy of pouring through the ACEA 2004 specification, I found this good summary:
http://www.gulfoilltd.com/products_s...ts1/index.html
A3/B3
"Modern formulation (called "mid SAPS") technology and synthetic base fluids combine to deliver a high performance engine oil, approvals by MB (229.31) and BMW LL-04, it also meets the ACEA A3/B4 and C3 specifications"
VS.
A5/B5
"Low viscosity, low friction, "low SAPS", yet excellent engine protection; this oil is designed for vehicles fitted with diesel particulate filters and three-way catalysts, for engines which require oils meeting ACEA A5/B5 and C2"
