993 Forum 1995-1998
993 to 993TT Calipers Swap
Old 01-30-2008, 05:00 PM
North Coast Cab
North Coast Cab's Avatar
Default 993 to 993TT Calipers Swap
Swapping my stock '95 993 calipers for a set fo '97 993 TT big reds. I thought is was a simple rotor and caliper swap, but in attempting to install the rear calipers I ran into a problem. The rotor is off center, too close to the inside, and is jitting the center "nub" on the caliper. The mounting bolts are not even tight yet and it looks like the will never be bale to get the ears flush.
A washer or shim shoudl fix the problem, but I wanted to make sure I wasn;t missing something first.
Old 01-30-2008, 05:11 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
They should be a direct bolt on. Be sure you are using the longer bolts for the TT front and rear calipers.
Could you post any pictures of the interference? Are the pad out of the rear calipers while you are trying to fit them?
Old 01-30-2008, 05:22 PM
North Coast Cab
Thanks Chris.
It appears to be my caliper issue. The ears have about 3/16" of material removed from them on the inside. My guess is someone tried to mount them to an early car or somehting to that effect. I'll machine some spacers and I should be good to go.
No dizzy yet. Playing hookie to get the car ready for paint.
Old 01-30-2008, 05:35 PM
TheOtherEric
TheOtherEric's Avatar
Yup, should be plug & play. Just need the longer bolts. BTDT.
Old 01-30-2008, 05:37 PM
Bill Verburg
Bill Verburg's Avatar
993RS/tt to 993n/a is definitely a bolt off/on
That's definitly the issue
are you using RS or tt rears?
Old 01-30-2008, 05:56 PM
North Coast Cab
TT rears. I just stacked up some shims and it pulled together perfectly centered.
Quick Reply: 993 to 993TT Calipers Swap
