Does anyone know this part number?
It is for the bolt on the middle of the picture which holds the lower arm of the right side muffler bracket. I cannot find it on the PET.
Thanks for your help.
Harry
Seared
Harry,
I just spent 5 mintues searching PET - to no avail. If you look at the camshaft housing illustration, you can clearly see the hole for the bolt - but no bolt.
I tried
Andreas
I tried
Andreas
Hello Harry, the firewall where I work does not display the picture you posted, but I presume you want
The 10mm bolt that attaches the right muffler bracket to the engine?
If so, knowing that the bracket is held by a hex screw from the top
The bottom bolt no. is 900.075.355.02 + washer N 011 524 7 there is one on each side.
Andreas was nearly there by a few centimeters, it holds on the engine block.
Take care, regards to Wallace
Thanks geolab and Andreas,
I believe it is a 13mm bolt and not a 10mm. I too like Andreas was looking at the camshaft housing illustration but nothing on it!
Harry
Harry
OK so how do I read the bolt sizes? On p-car.com the bolt is said to be 13mm - I think this indicates the size of the hexagonal head and the 13mm wrench fits so where does the 10mm come in? I need some education into how to identify the size of the bolts.
Harry
Harry
I think I have found some answers:
M6 (diameter of th bolt 6mm) X 10 (length of bolt) X 13AF (across flat = 13mm across the flat part of the hexagonal head) is what it should read (PET misses out 13AF).
Cheers.
Harry
Cheers.
Harry
OK the bolts suggested above are not the correct ones - doesn't matter 'cos I can use it for something else on the car. I think Andreas was correct - hole is there on the camshaft housing but ommission by PAG on their PET diagram. Porsche are looking into this for me.
Harry
Harry
