Recaro pole positions
I bought a pair of PP's and they came without mounting seat bolts. Does anyone who has mounted a set of PP's know the bolt size and length.
Thanks in advance Mark |
Are you talking about the side seat mounting bolts; from seat to side brackets?
Yes, side mounting bolts
Mine came w/ them so I'm not positive on the size but I think it is 8mm. I cross threaded one and had to get a tap, which wasn't easy to find in metric.
If nobody else comes forward, I can pull the bolt out tomorrow and let you know.
Call Mark at FVD and he should be able to hook you up with what you need.
Mine don't have tapped holes, they are just drilled through! This is strange. My old GT3 seats were tapped and had the bolts.
