993 Forum 1995-1998
Re-alignment needed when changing springs?
Old 01-15-2008, 10:48 PM
Acropora
Acropora's Avatar
Default Re-alignment needed when changing springs?
Toying with the idea of increasing springs from 500/700 to something stiffer. Was wondering if a re-alignment would be needed afterwards.
Old 01-15-2008, 10:54 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Even if you are targeting the same ride height with the new springs, alignment would be necessary. Also, you'll need to disrupt the rear toe settings and front camber settings to remove the dampers to change springs, more reasons an alignment is needed.
Old 01-16-2008, 02:51 PM
Acropora
Acropora's Avatar
Thanks Chris
Quick Reply: Re-alignment needed when changing springs?
