Thoughts on Leaving Oil cooler fan permanently on Hi
#32
Yes, but my point is, if you add the second cooler for the track, the oil runs cooler all the time, whether you are on the track or not, because you've greatly increased the efficiency of the oil cooling -- like you do if you run the oil cooler fan on high all the time. Which is not a bad thing, in my opinion.
#34
#35
