993 Forum 1995-1998
Fabspeed sport cats... Anyone have them?
Old 12-10-2007, 08:08 PM
melman911
melman911's Avatar
Difference between 100 and 200 cell cats? Sorry new to this. Thanks for any reply.
Old 12-10-2007, 08:52 PM
face-ache
face-ache's Avatar
Ok I'll bite, difference is 100cell, seriously, I would say less material and more free flow in the 100 cell count.
Old 12-10-2007, 09:05 PM
melman911
melman911's Avatar
Thanks. Not a trick question. Just ignorant to some things (not everything)
Old 12-10-2007, 10:25 PM
RDS928S
RDS928S's Avatar
As far as the Fabspeed sport cats-I talked to them yesterday and no dyno charts available. However they do have dyno info on their cat bypass pipes on a 3.8 engine. They noted 15 bhp. They deduce around 8 for their 200 cell sport cats. Labor is $70.00/hr @Fabspeed to install.
Not bad.
Rich
Old 12-10-2007, 11:21 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
Originally Posted by geolab
I need the exact diameter of the original catalytic converter, could anyone help me on this please?
The diameter of the catalyst not the tubes, should be between 3.5 - 4.5 inches, but I need the exact figure. Thanks
On my 1995 cat, the major diameter is 4.7"
Old 12-11-2007, 04:52 AM
geolab
geolab's Avatar
Thank you Chris, I intend to buy 2 x 100 cpsi cartridges and replace the OEM ones.
Old 12-11-2007, 08:38 AM
LAT
LAT's Avatar
Don't do the recell it doesn't work as well, you need the seperated exhaust thus the X pipes. I have the Cargraphic, they work great, no CEL's
Old 12-11-2007, 08:51 AM
geolab
geolab's Avatar
Sorry But I have got an M64-22 engine, one O2 sensor, and don't want fancy glitter underneath. I will just replace inserts, and reweld, cost $220
Old 12-11-2007, 09:09 AM
LAT
LAT's Avatar
Unnless your present system is plugged you will not get the benefit, just be spending money.
The Cargraphic are SS same color as the stock system, no Bling.
Old 12-27-2007, 05:48 PM
C4sport
C4sport's Avatar
Originally Posted by RDS928S
I know the Dach-x set up is widely popular but I need to rule these in or out before I join the DC group buy. My car already has Fabspeed supercup mufflers.
Thanks Rich
I just installed the Fabspeed Cat's more to try to save weight than anything else. The following are my impressions.
1) Only saved 10 to 15 pounds on Gillet Cat. I know they just copied the weight savings they had previously posted for there cat by-pass of 45 pounds. If the stock cat wieghs ~ 40lbs (bathroom scale) and you replace a good portion of that weight is hard to do the math to get to 45 lbs weight savings.
2) Perfomance, to my surpirse I actually can tell a difference more than the fabspeed maxflow mufflers with stock Cats alone. Or did it open things up enough to take advantage of the higher flow mufflers?
3) No instructions although fairly straight forward about four hours if you take it slow.
4) Do to the non crossover design one of the pipes protrudes below the re bumper 1 to 1.5 inches to snake aroungd the upper pipe, could be an issue with bottoming if your running low, although the larger fabspeed tips taht came with the maxflow mufflers may still hit first.
5) Right side after cat O2 sensor is in less than ideal location. Seeem like the tried to avoid a small removeable heat shield that I removed anyway to avoid the O2 wires from chafing against it.
6) Sound is just slightly louder than the fabspeed maxflow mufflers with stock cat and tad bit more metallic. The resonence at 2,500 to 3,000 rpm is less anowing. Quite a bit loader after 5,500 rpm but thats OK. No farting sound and absolute minimum closed throttle back fire.
6) Did not even try to really **** the neighbers off by trying the by-pass pipes (already the loudest car in the neighber hood) but test fitted them and seem to line up well will the exhaust cut outs.
Old 12-27-2007, 06:41 PM
LAT
LAT's Avatar
I believe Cargraphic claims 8-9 HP for this mod.
Old 12-27-2007, 07:12 PM
RDS928S
RDS928S's Avatar
C4 good review.
Do you feel they were worth the $1295?
Can you post a pic of the pipe hanging below the rear valance?
Thanks Rich
Old 12-27-2007, 07:15 PM
LAT
LAT's Avatar
I paid much more for the used set of CG I put on mine. If you are in the market that is a great price.
Quick Reply: Fabspeed sport cats... Anyone have them?
