993s with LSD?
100% of my 993 does.
Seriously, though, I don't know if even the factory has those kinds of records.
Don't let the lack of LSD in a 993 stop your from buying an otherwise fine car. 993 LSD's have two clutch plates versus the 964's four plates, making them an item that wears out quite quickly. Even if you found a car with LSD, there's a good chance that the disks will be toast. Guards Transmission can upgrade the LSD from a two plate to a four plate.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
50% of my 993's have the LSD option
To go from no LSD to a Guard LSD (or other), you need a new differential housing. To go from factory 2 plate to Guard 4 plate they just swap out the guts - you keep the same differential housing. Note, however, that not all 2-plate versions have enough space to refit with 4-plates. Guard told me they see all kinds of variations in the diff housing.
Basicly the street cars have a weaker version of lsd, so all normal 964 and 993 with M220 have that version which consists of 2 extrnally splined disk and 1 internally splined disk/side.
The motorsports trans used in 964RS and 993RS and 964t and 993tt used the more agressive lsd w/ 2 external and 2 internal disks/ side.
on 964 models the G50/10 and G50/52 were used in the RS and turbo respectively and also has 20/100 lock up as opposed to the 40% for street versions
on 993 models only the G50/30, 31, 32, 33 used in the RS and Cup versions used 40/65 as opposed to the normal street 25/65 or 22/40
