993s with LSD?
Note, however, that not all 2-plate versions have enough space to refit with 4-plates. Guard told me they see all kinds of variations in the diff housing.
Interesting, Bill. Do you know how many of the 4 types allow for use with 4 plates? Is it just the GKN type used for the motorsports LSD, or others as well?
g50/10, 52, 30, 31, 32, 33
Option M220 indicates an LSD. C4S also had LSD standard (so the option does not appear on the car's option sticker).
To go from no LSD to a Guard LSD (or other), you need a new differential housing. To go from factory 2 plate to Guard 4 plate they just swap out the guts - you keep the same differential housing. Note, however, that not all 2-plate versions have enough space to refit with 4-plates. Guard told me they see all kinds of variations in the diff housing.
Pull the lsd rebuild w/ Guard plasma sprayed friction disks and reinstall. There is no muss or fuss w/ shims etc as long as the same case is reused. I think Martin Schact recently went that route.
Downside is the car is out of commision for however long it takes to rebuild the lsd.
True, but my point is that one should not dismiss a car that does not come from the factory without LSD, especially if it's a street car. I added a limited slip to my car and it goes (and stops) just fine. On the track, I drive it a good bit harder than the average road-going 993 owner.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
That may be true but if you have the standard 2 disc LSD and the car has more than 30-40k, the discs are almost always toast and need to be rebuilt by Guard at a cost of around $750.00, so no matter what LSD you get or have, it is still a lot of $$$$$
ZP44
ZP44
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
