washer pump access?
washer pump access?
How easy is it to get to the screenwasher pump? I understand it's under the front left wheel fender. Is it much of a job? My washers stopped working since having suspension upgraded. Cant hear the pump, so I suspect wire has come off?
GG
GG
Jack up the car a bit and remove the left front wheel. Remove the plastic wheel well liner and you have access to the washer and all the wires. They may have simply not plugged it back in.
No need to jack it up and remove a wheel... On mine, I just pulled the LF headlight...open hood, rotate metal rod handle next to LF headlight which loosens the headlight assembly, and pull out headlight assembly, possibly disconnecting wires to fully remove it. Direct access to the two pumps (headlight and windshield washer pumps).
keith
keith
