No Help:Tapping Noise after Valve Gasket Replacement!
#31
thanks JC I am wondering why it should make a ticking noise?
#32
How would the lifters "dry" out? The biggest clue for me is, this tapping noise did NOT EXIST before I had the gaskets replaced.....now it does. There has to be a connection/relationship there.
It's like going to the dentist to have a tooth fixed, and when you leave your lip hurts, and your lip wasn't hurting before you sat in that chair for a few hours.
I know that sounds simple but how tricky can this be. The car was running fine, no unknown noises before the repair. Now it has this freakin' tapping, coming from the area where the work was done.
