SAI flush alternative...PLEASE REVIEW
all,
was wondering if it was possible to re-route the sai passages by drilling out new ones in the exhaust manifold??
has anyone tried this??
my friend has the dreaded CEL SAI code on his new '97 targa that he purchased last month and was wondering about alternatives as the flush seems like an involved process.
There was a thread a couple of months ago about bypassing the SAI check valve and routing 1/4" ID aluminum tubing to the threaded hole (with a bolt inserted) on the aft side of the exhaust. To see the bolt, you don't even have to jack the car up- just look up behind the rear bumper cover. There is one on each side of the exhaust less than a foot from center and facing aft.
I'll see if I can find the thread. Had pictures and details.
BTW- The mechanic did a "T" split before the SAI valve and ran a 1/4" tube to each side, but I am thinking that one could run one line toward the back and split it closer to the terminating points.
Seems like a pretty simple project. Maybe an hour and $30 for materials? Keep us posted and maybe list the materials and post a few pictures!
-Jim
Why bother? Just buy the part Turbowerx sells. It's cheap and does not require drilling holes permanently in your car. Re-routing risks not only permanent changes to your car, but also may not work with the OBD, which runs diagnostics before and after the SAI.
Check here:
http://www.turbowerx.com/Products/SA...iagnostic.html
Check here:
Check here:
Check here:
As for the tube bypass, it appears to work with OBD at least initially. No holes to drill that I can see. Maybe someone needs to get in touch with JRB964 and see how it's doing after a couple thousand miles.
-Jim
https://rennlist.com/forums/993-forum/269097-intermittent-hesitation-any-ideas.html
Jim, I PM'd jrb964 the other day and he is still running fine w/ no complications or SAI faults. He said he will try to get some photos of the pump/ valve end of the changes he made. The photos from the old thread shows the tubes connected to the exhaust through existing ports easily accessable from underneath the car.
Dennis
Dennis
Adrienne, are you using the TurboWerx tool? Is it a software fix/ change or???? I also was in contact w/ TurboWerx and they said they would e-mail me when device was ready for sale-no word as yet.
Dennis
Dennis
From what I hear the device was slowed down due to one of their suppliers for the enclosure letting them down....they have moved to another supplier and I hear it may be ready in the near future........by the way PM me if you want more info on its ability to work......I owe Adrienne big time for this information......
