Underbody brake line replacement question
I’m getting messy changing the ATF oil pipes and while I’m at it I thought I would change all the underbody brake lines as they are a bit corroded, especially at the front intermediate piece (which will also be renewed).
Is the long front to rear line a PITA to replace?
Is there anything that has to be removed to make it possible or easier?
