993 Forum 1995-1998
question regarding proper idle RPM
Old 10-16-2007, 08:07 PM
groovzilla
groovzilla's Avatar
Received 4,408 Likes on 2,686 Posts
Default question regarding proper idle RPM
i noticed my friends 993 idles at about 700
is there a factory preferred RPM setting??
i know 911sc's feel good about 700
Old 10-16-2007, 09:05 PM
AOW162435
Seared
AOW162435's Avatar
Your avatar - is it you, or Tony Little?
Andreas
Old 10-16-2007, 09:07 PM
groovzilla
groovzilla's Avatar
what are you some sort of comedian?
Old 10-16-2007, 09:10 PM
AOW162435
Seared
AOW162435's Avatar
No, simply curious.
As to your original question, I think you'll find most 993s idle at around 800 or just below. Quite a few Rennlisters have found success with a thorough cleaning of the Idle Speed Control Valve (top, middle of engine).
Andreas
Old 10-17-2007, 10:17 AM
Mark in Baltimore
Mark in Baltimore's Avatar
He tries with much sound and fury but often to little effect.
Old 10-17-2007, 10:55 AM
99three
99three's Avatar
The rough idle symptom is a 'characteristic' on some 993's. It’s a non issue but quite a few 993 owners have experienced rough idling and cleaning the ISV did nothing to cure the rough idle that I still experience on my 96. Including changing the caps/rotors and fuel filter. Plugs and wires are next on the list. After getting it assessed by my wrench, he confirmed that there was absolutely nothing wrong with my 993 even with only 39K.
If you are not exhibiting any codes (misfire) and it’s pulling hard, I wouldn’t lose any sleep over it.
Old 10-17-2007, 02:03 PM
mpgandco
mpgandco's Avatar
Turn your AC on low and it will bump it up a bit to smooth it out.
Quick Reply: question regarding proper idle RPM
