Something besides a visor or tint for the windshield?
Wondered if anyone could suggest something that would block out the sunlight at the top of the windshield? I would prefer something for the exterior that would be easily removed if I changed my mind instead of tinting. Flipping down the visor on the driver's side is a problem because of the location of my V1 and I like the V1 right where it is. Just looking for something low key without Porsche lettering or anything like that.
You could order some vinyl in a variety of types from a sign shop supplier. They have tons of colors and even gradients. You can apply this to the outside and it would be very durable and relatively easy to remove with a razor blade if you dont like it. Some vinyls are designed to be removed easier than others. If you go to a sign shop, some can print on clear vinyl, so you can make a pattern, like a graduated halftone so it fades. You can even do this on static cling vinyls that you could put inside you window and take off if you don't like it.
http://www.signmakerswarehouse.com/7....php?p=4&pno=0
There is an example of one of these suppliers
