993 TO 993TT ENGINE DIFFERENCES??
Old 10-10-2007, 07:43 PM
nitrorocket
User
nitrorocket's Avatar
Default 993 TO 993TT ENGINE DIFFERENCES??
I searched...
I want to know what differences there are in the 993 to 993 internal differences?
Block, crank, rods, cams, heads, etc.
All they all the same long block except for higher compression? Do they have different blocks or heads?? Anyone know all the differences?
nitrorocket is offline
Old 10-10-2007, 07:49 PM
Jay993turbo
User
Jay993turbo's Avatar
Rods and crank are the same. Heads, pistons, and cylinders on the 993tt are different. 993tt pistons protrude into the combustion chamber to reduce stress on cylinders during combustion, the cylinders are shorter, pistons have a flatter top for lower compression and the heads are single plug with different size valves than the twin plug 993. Maybe someone else (like Steve W.) will chime in with more detail.
Jay
Jay993turbo is offline
Old 10-10-2007, 11:33 PM
Napa Valley Realtor
User
Jay
The rods are reinforced as well.
Napa Valley Realtor is offline
Old 10-10-2007, 11:37 PM
nitrorocket
User
So it is possible with a rod and piston change to essentially be able to throw twins on it and have a tt car with a motor that will last.
Old 10-10-2007, 11:51 PM
Phil
Phlat Black Guru
Lifetime Member
- Times 2
Phil's Avatar
why not just buy a tt to begin with?
Phil is offline
Old 10-10-2007, 11:56 PM
Napa Valley Realtor
User
you would also want to add the forged cylinders.
i imagine the cost would be more than buying a TT. Also I really doubt resale would come close to equalling a TT.
Old 10-11-2007, 12:24 AM
poorb0yw
poorb0yw's Avatar
Agree with above. If you just want to go down the bolt on path, starting with a TT or trading in a NA car to get a TT would be far wiser. If you want to build something unique then start with whatever base you wish.
poorb0yw is offline
Old 10-11-2007, 08:43 AM
Bill Verburg
Bill Verburg's Avatar
Nope, bottom end is the same except for a few studs.
p/c are different as are heads(single plug on tt), valves, guides, cams, carriers etc. all different
Bill Verburg is offline
Old 10-11-2007, 10:19 AM
RallyJon
Weathergirl
RallyJon's Avatar
single plug on tt
Now why wouldn't you want to use twin plug heads on a turbo? The extra plug would let you run an extra point of compression for better response, or more boost. Is there some critical weakness in the twin plug heads that make them unsuitable for the TT?
RallyJon is offline
Old 10-11-2007, 04:12 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Protomotive has been (low-boost) turbocharging the stock 964 and 993 engine for a long time without problems (i think for around $8k).
JasonAndreas is offline
Old 10-11-2007, 08:23 PM
Napa Valley Realtor
User
I do not have first hand knowledge.
I am quoting Motor Trend:
"The Turbo's powerplant is basically the same as the powerplant used in the Carrera, only with lower compression, reinforced connecting rods, and upgraded engine cooling systems"
And Road & Track:
"The engine itself receives special tweaks to live under the maximum 11.6 psi of boost; Compression ratio is lowered to 8.0:1; and connecting rods, piston crowns and cylinder heads are reinforced"
It is quite possible the magazines were given the wrong information at the time and just quoted the spec sheets they were given.
Old 10-11-2007, 10:04 PM
Red9
User
Red9's Avatar
Bill Verburg is giving the correct answer.
Red9 is offline
Old 10-11-2007, 11:27 PM
JasonAndreas
Technical Guru
To get the complete list just look in the PET engine section for the turbo engine type designation M64.60 on the far right column next to the part description.
Old 10-11-2007, 11:37 PM
Jay993turbo
User
And Road & Track:
Rods and crank are identical. Same part#'s too.
Old 10-11-2007, 11:42 PM
Jay993turbo
User
Extensive machine work will be required for it to be identical to a TT engine. A good machine shop can do pretty much anything I guess but it's not worth it IMHO, better to just buy a TT engine.
Contact Us - About Us - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
