what part is this /used for ?
Hi guys,
This part clip got disconnected. Can anyone tell me what it is and what is it used for.
Thanks.
Najeeb
'95 993
Thanks.
Najeeb
'95 993
Thankx guys for the feed back.
James, yes t he clip on the far right fits their, i have soldered it. However, unsure where the positive feed goes.
i have soldered two wires to it. can u tell me if this is correct:
Clip
| |--------- +ve
| |--------- -ve
BTW, what is the change over valve used for ?
thanx again
'95 993
Clip
| |--------- +ve
| |--------- -ve
thanx again
'95 993
Where is the connector gone??? Do not solder. Get the valve out of the car and meet your local Mercedes-Benz dealer (Yes!). They also use this parts and connectors. Then solder a new connector to the wires. I think the pinning doesn't matter.
This electrical valve switches the vaccum line to the actuator of the resonance flap on the front side of the intake distributor. At ~5200rpm the valve opens, the actuator gets a vaccum and move the resonance flap to get higher engine torque. You should feel this "boost" performance when your car accelerates...
PDriver
PDriver
