Would dropping the engine slightly help with plug changes?
I read about and experience the #6 plug change issue. Would I gain anything by loosening the two rear engine mounts and lowering the motor a little using a 2K ton jack??? Local independent Porsche repair boasts the #6 plug change during a plug job - do they have a secret method of doing it - other than 'time' and the ability to 'stand' under the car? Comments?
Marlon it is not that big a deal. Even #6 is a piece of cake if you have the right tools. Get a new spark plug socket, a universal joint, a 3" extension and a stubby socket wrench. Use electrical tape to join them together to prevent any tools from dropping into the engine. There must be 50 threads on this method.
Seared
Marlon,
I replaced all 12 plugs earlier this year - with the car on four stands. As long as you remove the engine tin (from below) access is not as bad as some make it seem. I also replaced all four valve cover gaskets at the same time, so the job took a few days (fastidious cleaner.....).
Let me know if I can help.
Andreas
Andreas
Dudley/Andreas - thx for the info and moral support. I got all but three replaced very easily a couple weeknds ago (two behind a muffler and the infamous #6 still undun). I plan to do the lower valve cover gaskets when I tackle the other 3 plugs (yes, I got new bolts for the covers too). I really wanted to do the plug wires at the same time, but I pushed it off for a bit pending the recent thread on OEM vesus 'hand assembled' plug wires. jeesh. Sunset has the entire wire set for around 475.
