993 Forum 1995-1998
How accurate is your Oil Level guage?
Old 09-03-2007, 01:24 PM
McGarrett
McGarrett's Avatar
Default How accurate is your Oil Level guage?
My Oil Level guage seem to stick a bit. A little tap and it usually pops back to life. Is this normal?
I'm thinking of just sending it out to North Hollywood Speedometer.
Old 09-03-2007, 01:30 PM
Dan V
Dan V's Avatar
Mine is spot on -- thanks for asking!
Old 09-03-2007, 01:41 PM
997Heaven
997Heaven's Avatar
mine does the same thing , let me know if the repair works
Old 09-03-2007, 01:42 PM
Edward
Addicted Specialist
Edward's Avatar
Hi McGarret,
If you've got to tap it to unstick, no, not normal ...up to you whether to address it though as you should always rely on the dipstick. FWIW, my gauge is spot on like Dan's, so it is worthwhile to have as an "indicator" guage.
NH is great ...sent an Alfa Tach to them years ago and they are prompt and good at what they do.
Edward
Old 09-03-2007, 05:57 PM
Denise993
Denise993's Avatar
Mine reads low all of the time. It was in the red just last week (after 30 min. warm up, idling on a level surface). I drove to my shop and the guys checked the dipstick for me. It was PERFECT. I can't rely on it at all. If you get it repaired, I'd love to know how it turns out.
Old 09-03-2007, 06:41 PM
c993k
c993k's Avatar
Perfectly accurate, however I check my stick every 500 miles just to be safe.
Old 09-03-2007, 06:46 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
chris walrod's Avatar
+1
Old 09-03-2007, 07:05 PM
GabiOsz
GabiOsz's Avatar
Sticky needle, my oil pressure gauge does this, let us know if they can fix it for a reasonable amount. There are guys here that offer instrument servicing, so interested to know if it can be fixed without spending £££s.
Old 09-03-2007, 09:48 PM
Slow Guy
Slow Guy's Avatar
Mine does this too. I suspect it's more an adjustment of the arm of the sending unit in the oil tank than the gauge in the dash.
Chris, is this correct?
Old 09-04-2007, 09:43 AM
tabasco
tabasco's Avatar
Default Can't read the dipstick
I have a hard time reading the dipstick.
There's probably some oil that remains in the tube that gets on the stick as I pull it out. So I can't clearly see the limit. I usually do it like 10 times in a row to guess where the level is, and I'm still not sure.
Anybody got a good tip to get a more accurate reading on the dipstick ?
Is yours easy to read ?
I'd like to rely more on the dipstick rather than the guage.
Old 09-04-2007, 10:36 AM
99three
99three's Avatar
I check it a dozen times before I'm convinced what the oil reading is. Anyone have any tips on getting done in half the time?
Old 09-04-2007, 10:47 AM
AOW162435
Seared
AOW162435's Avatar
My gauge works great.
Send yours to NHS - I've dealt with them numerous times.
Andreas
Old 09-04-2007, 11:35 AM
TrackJunke
TrackJunke's Avatar
As for checking the dipstick, generally I can see a small area where you can see some bubbles and a little more oil on the stick. This is what I take as the level. Seems consistent. Above it will be some more oil but you should be able to see the difference.
Old 09-04-2007, 11:41 AM
Denise993
Denise993's Avatar
When I drove to the shop a few weeks ago, I made my mechanic show me how to read the dipstick... because I couldn't figure it out either. His tips:
Car has to be warmed up for at least 30 minutes... must be running and on flat, level ground
As you pull out and push in the dipstick, let it twist (of course, clean it off the first time or two you pull it out)
Look at it in direct sunlight (my oil is really clean and hard to see in my garage)
Flip the dipstick over (sometimes the oil lays on the edges, but you can't trust that) look for the oil on the flat side of the twists.
A good oil level is in the middle of the twists... he said less oil is better than overfilling in these cars.
Does that make sense? I'm not explaining this as well as he did... it's kind of a visual thing.
Hope that helps!
Old 09-04-2007, 02:03 PM
ZombiePorsche44
ZombiePorsche44's Avatar
Mine is a about as useful as **** on a bull.....use the dip stick if you really need to know how much oil is in the car.
ZP44
Quick Reply: How accurate is your Oil Level guage?
