How accurate is your Oil Level guage?
#31
I agree with everything you say there Bill , it takes a bit of time for the oil temp to get to the 3 o' clock temp (approx 230f , when the low fan kicks in) but it's at this temp that I find my oil quantity gauge works best.
You won't see that 230f temp unless the car is sitting for 10-15 mins with the engine running , after the oil has come up to the 194f level for the second time (ie the oil cooler valve has opened)
Crikey , it really isn't that complicated ! .. Sorry for making it sound like it is!
#32
I think you mean 9 o'clock on the temp gauge (unless the location is swapped in Ireland). Unfortunately (or fortunately in my opinion) my car rarely sees 9 o'clock and I'm not going to try and get it up there, other than in spirited driving, if I can help it.
I think for all practical purposes we agree on the procedure, just go about it a little differently.
#33
#35
The gauge is operable. But in order to bring it up to the 3 O'Clock position, I would need to top off the oil, which I don't want to do, as any amount over mid point is quickly consumed.
Given that the guage operates, is the sending unit still suspect? Is there a way to calibrate this?
#36
If it gets to the 230F (9 o'clock position ?) I'm not concerned about it, however, since mine seems to (normally) run cooler than that I'm happy. Personally, I wouldn't start getting anxious until it got to the mark at the 10 o'clock position. I think mine's only been that hot once and all I did was check to make sure the oil lines to the cooler were warm (indicating the thermostat was open) and that the fan was running.
#38
Very bad idea. This advice is best not taken.
#39
I got slapped
For the record , this tip was given to me by a Porsche tech with 17 years experience , so he was weened on air coolers. The reasoning is that it gets the car up to oil fan/level testing temps quick without running the engine on idle for longer periods of time... I wouldn't see a problem as long as you kept an eye on proceedings ..
But I'm no techie , so I'd be very interested to hear why this would be a bad idea ..
#40
The reason it's not a great idea is simply that an air-cooled motor relies on, well, air to cool things like the cylinder heads. Sure, putting a blanket over the decklid grille will heat up the engine quicker, but you might also end up with hot spots on the motor. Especially being that getting a 993 motor up to temperature the old-fashioned way -- by driving it -- is not all that difficult a thing to do.
