993 Forum 1995-1998
Big Brakes -- heads up
Old Aug 27, 2007 | 01:22 PM
chris walrod's Avatar
chris walrod
Guru
Rennlist Small
Business Sponsor
Default Big Brakes -- heads up
This is the second big brake kit I have seen in two weeks. No reserve auction, and no affiliation.
http://cgi.ebay.com/ebaymotors/Bremb...mZ290154370957
Old Aug 27, 2007 | 01:28 PM
RallyJon's Avatar
RallyJon
Weathergirl
Very suspicious. Both the seller's account and his only visible feedback are recently active after years of dormancy.
Old Aug 27, 2007 | 01:30 PM
AOW162435's Avatar
AOW162435
Seared
Yum! And from the same seller I think. Does this require 19" wheels?
Andreas
Old Aug 27, 2007 | 02:20 PM
pcar964's Avatar
pcar964
Andreas
My question exactly
Old Aug 27, 2007 | 02:31 PM
chris walrod
Guru
Rennlist Small
Business Sponsor
Originally Posted by pcar964
My question exactly
A 380mm rotor will more than likely require a 19" wheel. I made a set of hats for a RUF braking system that uses a 380mm rotor, and 19" wheels were a must.
Old Aug 27, 2007 | 03:05 PM
allill's Avatar
allill
I like it! Is this a direct replacement or would other parts be needed?
Old Aug 27, 2007 | 03:31 PM
Bill Verburg's Avatar
Bill Verburg
25 Year Member
Way more brake than a n/a 993 will ever need, you would still need rears as well.
JMO but why would anyone ever put something bigger than RS on their n/a 993.
Old Aug 27, 2007 | 03:45 PM
pcar964's Avatar
pcar964
I believe that can be summed up in one word: bling
Old Aug 28, 2007 | 09:38 AM
DaveM993's Avatar
DaveM993
+2
I guess some want to show they can trigger the ABS with Hoosiers on a nice hot dry day...
Old Aug 28, 2007 | 11:04 AM
chris walrod
Guru
Rennlist Small
Business Sponsor
Absolutely!
Old Aug 28, 2007 | 12:48 PM
Greg H.'s Avatar
Greg H.
You don't want those brakes. I have the brembo 355mm kit and its almost too much. And brake pads cost a fortune.
Greg H.
Old Aug 28, 2007 | 02:27 PM
David Ray's Avatar
David Ray
You'll have to get larger stone guard plates as the bigger rottors will rub, or just don't use them.
