Is My Clutch Going?
Robin,
Yeah, that sounds like it for me. Can you just drop the tranny w/o the engine? Is there enough room to get input shaft out of the clutch assembly? If so, I may be doing it sooner than later.
Thanks for the input.
Lifetime Member
Lifetime Member
Some shops will drop the tranny without removing the motor, they just loosen the motor mount to get the motor to "hang" in order to access the top tranny bolts. Which basically saves the trouble of draining the oil and removing all the harness. Sometime it can take longer...., I guess the good news with that method is that you don't need to get a alignement afterwards, since you don't need to remove the engine craddle and the suspension components associated with that? (Not 100% sure on that, as I haven't done this)
I posted the outcome of this situation on another thread but will repeat it here for the sake of others who replied with similar symptoms. After leaving my 993 with a mechanic for a day, he drove it extensively and arrived at the conclusion that the pilot bearing had either seized or was seizing. We discussed the options and I elected to have him correct the problem and do a clutch change out because I am at 60k anyway. I also have a small oil leak and will have him do the hard, upper valve cover gaskets and of course the main seal and whatever else he thinks would be appropriate while the motor is out.
The mechanic has a friend who works over 993 transmissions and will open mine up for a minimal charge. I know the 2nd gear synchronizer is going so now is the time to get it all right. If he finishes this week, will take a road trip North, just to get reacquainted. No break-in period for a new clutch I wouldn't think. Thanks for the suggestions on this odd, intermittent problem.
Thanks for the rundown Robin. I noticed you mentioned checking the flywheel. Better to just replace it while there? I think I have read it cannot be resurfaced. Recently while replacing the plugs and wires, I removed the power steering pump to get at the last bast^*! plug. The belt looked ok, with no cracks. Do you advise replacing it anyway while there? I want to cover all bases and do it right. Thanks.
Lifetime Member
Lifetime Member
Replace it!
