993 no fuel to engine
Hi all,
Yesterday I acquired a 1994 993 which started fine first turn of the key in the morning, but later on in the evening it refused to start.
I examined the plugs and disconnected the fuel supply line to the engine, and sure enough no fuel is coming through the filter.
I have changed the DME relay (the old DME works in my 964 anyway so it wasn't that) and checked the fuel pump fuse, what next?
Also on a different issue the oil dipstick is showing as full with a cold engine - roughly how much should I drain out to get it to the correct level? It has not been run for more than couple of minutes like this fortunately.
Many thanks in advance,
Bryn.
Bryn.
If you bridge #30 to both 87 & 87b in the 'DME' relay socket ( 3-way jumper), does the pump run? If so, and the DME relay works in your other car, then the trigger signal that closes the relay is likely the problem .... #86 to #85: that can be a poor ground, break in the wire, DME connector pin corrosion, etc.
If the pump does not run by doing the above, I'd e tempted to run a fused +12v directly to the pump after checking that it has a good ground.
Thanks for the advice guys.
I tried bridging the terminals but no luck although I was using a paper clip so might try something more substantial tomorrow.
No idea about the immobilizer, how can I tell?
Thanks again,
Bryn.
Thanks again,
Bryn.
I only have the one key for the car, and no remote.
If I lock the car with the key in the door, the red lights on the door pins start flashing.
Does this indicate the immobiliser?
Many thanks,
Bryn.
Many thanks,
Bryn.
I'm still trying to resolve this problem but no luck so far.
Got a new DME but nothing, so I tried connecting a 12v supply direct from the battery to the fuel pump.
I just want to check - on my car I have a brown wire and a black/green wire going to the fuel pump. I assume black/green is positive?
Sorry for the stupid question but I assume the fuel pump SHOULD be earthed and I just need to run the one wire for the +12v?
So I guess if with the +12v connected direct to the pump there is nothing then it is either the fuel pump or a bad earth? Where should I check for a bad earth?
Many thanks in advance for any help - its driving me nuts now
Cheers,
Bryn.
Yes, I would also first check for a good earth/ground connection : that is a conductivity test ( looking for 0 ohms) from the brown wire at the pump to any bare chassis metal. Then take the fused +12v to the other connector, and the pump will do its best to run ...
Afternoon guys,
Just thought I'd let you know that I have now resolved this.
The solution was to clean the battery clamp terminals. Incredibly the car still turned over fine but it seems that the dirty clamps were not giving a good enough earth to run the fuel pump.
So I guess the moral is try the simple things first!
Thanks for all your help,
Bryn.
Bryn.
