CD Player
CD Player
My CR-210 does not "see" home made CD's...Is there a different software I should use to burn them maybe, or...??
Has anybody here experienced the same thing?
Mine works fine with homemade CDs. Make sure you recorded the CD in the audio format and not the data format. To check try it in your home CD player. If it works in the home player it should work in your car.
Media makes a difference
What is the blank media that you're using? In general CD-Rs work better on older equipment than CD-RWs. Even amongst CD-Rs, some brands work better than others.
Maybe try a few different types of media and see if your results are consistent.
- Dave
- Dave
